NH 114 Haybine Hydraulics
   / NH 114 Haybine Hydraulics #1
jredshoes
Picked up a NH 114 swing arm haybine today and don't have access to a manual (yet). It has 3 hydraulic hoses and I am trying to figure out exactly which hose is what. Any help would be appreciated. Thanks.
   / NH 114 Haybine Hydraulics #2
plug them in and see what happens when you move levers. If it is like the Gehl I have used there will be a valve you need to open on the cylinder of the swing arm. This valve is a lock when closed, when open it allows the arm to swing. The only way to really see what each hose does is to either track them down and mark them or plug them in and see what it does.
   / NH 114 Haybine Hydraulics #3
New Holland usually pairs two hoses (tubes) and clamps one separately as they run down the tongue. The pair will operate the swing cylinder left and right. The single line operates the lift cylinders which are probably a master/slave setup. You will need two remote valves to operate this machine efficiently.
2008 Ford F-250 4x4 Pickup Truck (A50323)
2008 Ford F-250...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
2012 Ford F-450 Versalift TEL29N 29ft Bucket Truck (A50323)
2012 Ford F-450...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
Genie GTH-844 (A50120)
