NH 114 Haybine Hydraulics
   / NH 114 Haybine Hydraulics #1
jredshoes
Picked up a NH 114 swing arm haybine today and don't have access to a manual (yet). It has 3 hydraulic hoses and I am trying to figure out exactly which hose is what. Any help would be appreciated. Thanks.
   / NH 114 Haybine Hydraulics #2
plug them in and see what happens when you move levers. If it is like the Gehl I have used there will be a valve you need to open on the cylinder of the swing arm. This valve is a lock when closed, when open it allows the arm to swing. The only way to really see what each hose does is to either track them down and mark them or plug them in and see what it does.
   / NH 114 Haybine Hydraulics #3
New Holland usually pairs two hoses (tubes) and clamps one separately as they run down the tongue. The pair will operate the swing cylinder left and right. The single line operates the lift cylinders which are probably a master/slave setup. You will need two remote valves to operate this machine efficiently.
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
1977 Cat 910 Wheel Loader (RUNS) (A50774)
1977 Cat 910 Wheel...
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
2010 Toyota Tundra 4x4 Crew Cab Pickup Truck (A50323)
2010 Toyota Tundra...
Parkson 3000A Feed Mill (A50121)
Parkson 3000A Feed...
2013 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400lb 3 Ton Mechanics Crane Service Truck (A50323)
2013 Ford F-550...
