NewHolland Grill Guard - Plugs for tubes
   / NewHolland Grill Guard - Plugs for tubes #1
TCowner
Platinum Member
SE Minnesota
John Deere 4720 Cab
I just installed the grill guard on my TC40DA. The horizontal part of the guard is basically steel tubing probably about an inch and a half in diameter. The ends are open which will allow dirt and moisture to accumulate.
I installed a brush guard bumper on a Polaris ATV a few years ago that also used the steel tubing but included some plastic "plugs" that were inserted into the tubing.
Any ideas on where I can get something similar for my NewHolland grill guard?
   / NewHolland Grill Guard - Plugs for tubes #2
These are the folks that make them for most all applications. caplugs click here
Once you find the ones that work kindly post your results here as there are probably more than a few folks including myself that I think would be interested.
   / NewHolland Grill Guard - Plugs for tubes #3
Metal grommet and hole plugs like used to patch a hole where a antenna went will probably work.. they are spring loaded.. etc.
Soundguy
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2009 KENWORTH T6 SERIES SLEEPER (A52576)
2009 KENWORTH T6...
2011 KOMATSU PC56-7 EXCAVATOR (A51246)
2011 KOMATSU...
