Buying Advice Newby seeks help with buying a tractor.
   / Newby seeks help with buying a tractor.
What if I said our original budget was $20,000?
Honestly?
Kubota L4400 DT does have loader, skid steer coupler and 72" square back bucket. Haven't heard back if it's 4wd or?
What is better more hp or a heavier, wider tractor?
   / Newby seeks help with buying a tractor. #35
Maggie,
The Kubota L4400 sounds to be worth investigating. The DT says it is a 4wd with mechanical/manual transmission. The physical size, weight and horse power of the L4400 may well be a good fit for your needs.
There should be room for price negotiating at $20,750 or perhaps a used implement that you can use, thrown into the deal.
   / Newby seeks help with buying a tractor. #36
Ok. So here are my options:
Mahindra 5035 HST $28,990
Mahindra 4035 HST $23,590
Kubota MX5100 HST (new) $32,262.38
Kubota MX5100 HST (Harvest rental with 156 hrs and 1a hydraulic remote) $31,400.56
Kubota L4400 DT (Used with 300a hours and manual) $20,750+tax
Do the prices for the two MX5100s include backhoes???
See, people keep saying an MX5100 isn't $10k more than my LS, but I only paid $21,500 for mine new....with FEL, QA bucket, dual remotes, HST, rear work light, adjustable 3pt lift arms and stabilizer bars, etc. I keep hearing people suggest they can buy an MX5100 new for $25-27K, but I'm not seeing that.
   / Newby seeks help with buying a tractor. #37
Depends on what you're trying to do, and the conditions...there really isn't a stock answer. Some jobs put traction at a premium, and others HP.
   / Newby seeks help with buying a tractor. #38
To me, HP, you can always add weight and widen tires, but you can't easily add HP
   / Newby seeks help with buying a tractor. #39
IMG-20131019-00652.jpg its in texas but good price
2015 Ford F-750 Stellar 10628 10,000lb. Mechanics Crane Service Truck (A56858)
2015 Ford F-750...
TEST YOUR BID BUTTON! (A58374)
TEST YOUR BID...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
Troy-Bilt Push Mower (A55973)
Troy-Bilt Push...
