Buying Advice Newby seeks help with buying a tractor.
   / Newby seeks help with buying a tractor.
What if I said our original budget was $20,000?
Honestly?
Kubota L4400 DT does have loader, skid steer coupler and 72" square back bucket. Haven't heard back if it's 4wd or?
What is better more hp or a heavier, wider tractor?
   / Newby seeks help with buying a tractor. #35
Maggie,
The Kubota L4400 sounds to be worth investigating. The DT says it is a 4wd with mechanical/manual transmission. The physical size, weight and horse power of the L4400 may well be a good fit for your needs.
There should be room for price negotiating at $20,750 or perhaps a used implement that you can use, thrown into the deal.
   / Newby seeks help with buying a tractor. #36
Ok. So here are my options:
Mahindra 5035 HST $28,990
Mahindra 4035 HST $23,590
Kubota MX5100 HST (new) $32,262.38
Kubota MX5100 HST (Harvest rental with 156 hrs and 1a hydraulic remote) $31,400.56
Kubota L4400 DT (Used with 300a hours and manual) $20,750+tax
Do the prices for the two MX5100s include backhoes???
See, people keep saying an MX5100 isn't $10k more than my LS, but I only paid $21,500 for mine new....with FEL, QA bucket, dual remotes, HST, rear work light, adjustable 3pt lift arms and stabilizer bars, etc. I keep hearing people suggest they can buy an MX5100 new for $25-27K, but I'm not seeing that.
   / Newby seeks help with buying a tractor. #37
Depends on what you're trying to do, and the conditions...there really isn't a stock answer. Some jobs put traction at a premium, and others HP.
   / Newby seeks help with buying a tractor. #38
To me, HP, you can always add weight and widen tires, but you can't easily add HP
   / Newby seeks help with buying a tractor. #39
IMG-20131019-00652.jpg its in texas but good price
David White Meridan LT6-900 Level Transit, S/N D94224 (A59076)
David White...
Terms & Conditions of (Buying through EquipmentDealz Auction) Continued (A59213)
Terms & Conditions...
2025 GPS Trailers (A56857)
2025 GPS Trailers...
Gradall 53409-45 Telehandler, Turbo Diesel Engine, 45' Reach, Rear Steer, 60" Forks, 6,699 Hours (A59076)
Gradall 53409-45...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
2020 DRAGON ESP...
