Newby here
   / Newby here #1
JC Cooper
Ford 3000
Just signed up as I'm going to make an attempt to get the old Ford 3000 going again. I bought it back in 1974 From my Father-in-law and used it for years. It got a lot of abuse and rust and so a couple of years (five actually) I decided I'd tear it down (bodywise) and replace wiring harness, gages, fuel lines and do some body repairs and paint and clean it up. As luck would have it, right after I got it taken apart and tracked down a lot of parts, I was diagnosed with an aortic aneursym and had the open surgery. By the time I got over that I was pushing 70 and kinda wearing out. In the middle of all of this I was building a house which the wife said I'd finish before I died or worked on that dang tractor again.
Well, here I am, about to start on the tractor. Just wanted you folks to know that I'll probably be calling on y'all for some pointers. My first question, in case I forget to ask it when the time comes is, what needs to be done before starting a diesel back up after it's been sitting for 5 or 6 years?
   / Newby here #3
Hello & WELCOME to TBN!
I moved your thread to the Ford Vintage Tractors Forum. :)
   / Newby here #4
Howdy
first thing I'd do is try to turn the engine over by hand ( with a tool ) and make sure that she was not seized.
next I'd drain the old fuel out, and then replace the fuel filters after cleaning the tank and blowing the lines out. crack lines at the injectors and crank over till they bubble and weep fuel.. tighten up and then try to crank over. if no crank, pull start her assuming it has a regular gear tranny and not an SOS tranny.
if the engine is seized, don't try this.. post back.
soundguy
2007 Chevrolet Tahoe 4x4 SUV (A51694)
2007 Chevrolet...
Freighliner Tender Truck (A53473)
Freighliner Tender...
2014 MACK CXU DAY CAB (A54607)
2014 MACK CXU DAY...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
CUSHMAN HAULER PRO GAS GOLF CART (A51406)
CUSHMAN HAULER PRO...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
