Newbie Tractor Owner Gets An Old Diesel Tractor, recommendations for engine oil
   / Newbie Tractor Owner Gets An Old Diesel Tractor, recommendations for engine oil #11
Does look good
   / Newbie Tractor Owner Gets An Old Diesel Tractor, recommendations for engine oil #14
I would use a 15-40 oil, my preference would be a synthetic.
But on a new to me old tractor I would be likely to do a couple of short hour oil and filter changes,
in case the engine is a bit gunked up.
This is the guidance I would follow exactly, I would probably use traditional for the short hour changes (the cheapest 15 40 diesel oil I could buy) then t6 or whatever you like for the long run.
Best,
ed
   / Newbie Tractor Owner Gets An Old Diesel Tractor, recommendations for engine oil #16
Oil specs in the '60's were ML,MM,&MS.
Motor Light,Medium,& Severe.
I think?
Awesome —- THANK YOU!!!!!
   / Newbie Tractor Owner Gets An Old Diesel Tractor, recommendations for engine oil #19
15W-40 HDEO year round for your location. Ok for cold starts and hot weather use. Better oil capability then the engine was ever designed to. Lowest cost and likely available.
How many hours will you use the tractor per year? If under 100 hours just change oil one time per year and do not add hour meter. If adding hour meter keep that original Tach with the Eagle and use aftermarket only hour meter.
I have zero —- ZERO —- intention of touching that original tach!
any hour meter would be on its own bracket, under the hood.
I had been guessing at good ol’ Rotella. . . But really was looking for contrarian viewpoints, just to expand my learning.
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52141)
2015 VOLVO VNL...
2013 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2013 INTERNATIONAL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE 6X4 MID ROOF SLEEPER TRUCK (A51219)
2016 FREIGHTLINER...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2008 International 4400 (A50323)
2008 International...
Quick Attach Pallet Forks (A47384)
Quick Attach...
