LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 12,290
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Does look good
Of COURSE I have to get the tractor WITHOUT an hour meter. . .Does look good
This is the guidance I would follow exactly, I would probably use traditional for the short hour changes (the cheapest 15 40 diesel oil I could buy) then t6 or whatever you like for the long run.I would use a 15-40 oil, my preference would be a synthetic.
But on a new to me old tractor I would be likely to do a couple of short hour oil and filter changes,
in case the engine is a bit gunked up.
I think I will keep the eagle —- but I definitely bookmarked that website! THANK YOU!!!!!If you want;
Case 430 470 530 570 730 830 930 1030 Tractor Tach Tachometer | Saeli | Saeli
But it doesn't have that proud eagle in it.
I have zero —- ZERO —- intention of touching that original tach!15W-40 HDEO year round for your location. Ok for cold starts and hot weather use. Better oil capability then the engine was ever designed to. Lowest cost and likely available.
How many hours will you use the tractor per year? If under 100 hours just change oil one time per year and do not add hour meter. If adding hour meter keep that original Tach with the Eagle and use aftermarket only hour meter.
