Newbie to tractors shibaura tractor s 2000
   / Newbie to tractors shibaura tractor s 2000
Thank you. I will look today
   / Newbie to tractors shibaura tractor s 2000 #22
Does it have a spin on hydraulic filter?
I don't know where to tell you to look for a strainer/screen. Some have it on top of the hydraulic pump (under a cap), Here is a video of a Shibaura built Ford to give you an idea. (I think this type of screen/strainer would be on one end or the other of the hydraulic return tube.
The starter on the tractor has met its maker. As you know technically this tractor is a ghost. The engine model number is c201-5000046. I have enclosed pictures of the starter. I just came back from the local tractor repair shop and they can not find out what to replace it with. No numbers on the starter at all to cross reference it. Does anyone have any ideas. I don稚 truly know if this is the correct starter that came with it or if it was just replaced with something that worked thank you for any help. F0DDCD36-04FA-4875-B60E-047D85F34BBD.jpeg21EFC67B-A54D-4D5E-A4E2-08A929BE3F94.jpeg79B56696-DF33-4505-9FA4-96D0151EB3DF.jpeg8D2569A8-BEF6-4977-9F5E-2ED104706988.jpeg40FF00DB-9757-4BD7-B575-2B2AADC04D34.jpegCF17695A-F42F-4DDE-BE92-946EE1F56DAB.jpeg79BF152F-23F5-41AA-B088-3E3F75D06D91.jpeg
   / Newbie to tractors shibaura tractor s 2000 #24
You might check with an Automotive Electrical Shop. They rebuild starters and alternators.
If all else faiils, call or email Shibaura
IHI Shibaura Machinery Corporation
   / Newbie to tractors shibaura tractor s 2000 #25
These are the Shibaura 4 cylinder tractors under 60hp listed by tractor data. They seem to be 2.0, 2.1 or 2.3 litre engines.
Thank you for your help !
   / Newbie to tractors shibaura tractor s 2000 #27
It looks like the Ford (Shibaura engine) used the same starter for Ford New Holland Compact Tractor 1000 1500 1600 1700 1900 1910 2110
Ford 1920 and 2120 might also be candidates
Thank you it is so hard to distinguish between what should be on there and possibly what I have
   / Newbie to tractors shibaura tractor s 2000 #29
That Ford 1910 Starter Fits a bunch of stuff. Maybe you can compare it to yours.
   / Newbie to tractors shibaura tractor s 2000 #30
I looked at all the Shibaura starters on ebay. Most of the others had a "hood" or mounting holes not on centerline, or more than 9 gear teeth. This one looks like the right mounting surface and 9 teeth. The only thing is that the "backpack" is oriented wrong. I'm not sure there is room on your tractor for that to angle down.
NEW 12V IMI PERFORMANCE STARTER FITS NEW HOLLAND 191 3-14 SHIBAURA S13-29 | eBay
2006 Mack CV713 Granite Truck, VIN # 1M2AG11C36M039886 (A51572)
2006 Mack CV713...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
2013 Ford F-150 Pickup Truck, VIN # 1FTFW1EFXDFB07930 (A51572)
2013 Ford F-150...
2022 Ford F-150 Pickup Truck (A51692)
2022 Ford F-150...
