Newbie Question
/ Newbie Question #1
Spike56
Platinum Member
Lexington, Texas
JD 2355
I was wondering if anyone sells a combination disk, renovator, planter unit. I had a renovator, which I sold a few years back. I believe it was a Hay King model (5 shank). I routinely had to raise (2) shanks to use since my tractor was only 55 HP and had trouble with 5 shanks.
The reason I am asking this question is the renovator had a row of disc's in front of the shanks. With this setup, would it be possible to remove the shanks and mount seed boxes ? Can you do this ? Does anyone do this ? I only want to use a planter on a very limited basis, as with the renovator and disc. On the disc, it would only be used to occasionally break up the top crust, maybe put out rye grass ? I have a turbo spin seeder.
The planters I have seen ,even small ones, for food plots are very expensive, and I cannot justify buying one.
I do not have a lot of land. The only things I would plant would be over seeding pasture with clover / vetch.... once a year on a couple 2-5 acre plots.
:confused:
/ Newbie Question #2
/ Newbie Question
Jeff, These appear to be what I was looking for. Thanks very much !:)
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A63689)
2017 Yale GLC050VX...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
60in. Work Bench (A65640)
60in. Work Bench...
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
AIRMAN SDG25 GENERATOR (A65643)
AIRMAN SDG25...
