Newbie quesstion Proper operation of Diesels
   / Newbie quesstion Proper operation of Diesels #11
LWB said:
Along the same lines, but I haven't it seen mentioned here before, my JD dealer recommends either off road fuel or upper gear lube. He says a lot of the CUT's he sees in the shop have "dry diesel" (over the road fuel) related problems. I didn't know there was a difference, except for the dye and the price. :confused:
I haven't heard of this. Can you be more specific about his concerns?
I'm wondering if he's talking about the low sulphur diesel being sold at stations now. This fuel is designed for low emissions. The lower sulphur content reduces the lubricity of the fuel, apparently.
I did a search. I reckon this article may answer my question:
Latest Penn State College of Agricultural Sciences News
Any thoughts on additives?
   / Newbie quesstion Proper operation of Diesels #12
Hi:
I haven't pulled 'out' a bunch of stuff but I have pulled over small trees (after making a cut) with my 2305. One thing though is that I pull from the drawbar hole, not the 3pt hitch.
If you can pull from a point below the axle you'll actually help pull the front end down instead of up (right at the axle it would be neutral). There are two things trying to lift the front of the tractor - the torque from the axles (Which we don't effect by moving the attachment point except via traction), and any 'pulling' force above the rear axle - A very high point will pull you over easily - Picture fastening a rope to the top of the rops, you'd wheelie easlily. Basically the attachment point is either helping the torque flip over the tractor (higher than the rear axle) or counter acting the torque reaction (below the rear axle). [neutral right at the rear axle].
The drawbar can also be pretty high and the center link is also pretty high IMHO.
A disadvantage of a low attachment point is less traction than if you fasten above as by fastening above you do shift weight onto the rear wheels adding traction but as mentioned previously a reverse rollover can happen.
   / Newbie quesstion Proper operation of Diesels #13
Whenever possible, I use a 4" strap for pulling bushes or old stumps. I leave some slack in the strap and yank it in a few pulls rather than just one. Some I have to pull pretty hard but always in "inertia" pulls, I guess you could say to avoid spinning wheels.
   / Newbie quesstion Proper operation of Diesels #14
I'm surprised the idle speed on your tractor isn't about 1,000 rpm. Mine was set for about 1,500 when delivered, but the manual says (for my 4010) 1,000 after breakin. I readjusted the throttle cable to get this after a few hours on the engine. This is what I throttle back to when not working it and after it has warmed up. I'd shut it down if you're idling much more than a couple minutes, particularly on a slope (for safety, brake on AND in gear, with engine off). Think on my 240D, the idle speed is about 850.
As another contributor mentioned, folks in the north have often left their diesels idling (at 850-1,000 typically) all night rather than risk their fuel waxing up in the winter. There are fuel additives to prevent this, as does 1/3 to 1/2 kero in the fuel, but this isn't what you asked about.
Another contributor pointed out a VERY IMPORTANT safety consid for working with chains. ALWAYS plan for where it might snap to if it breaks. My father once connected a chain to our car and went to pull it with our tractor. The chain snapped and made a nice chain-like-impression gully down the hood of the car. Fortunately, it was just short of breaking the windshield. If I were to use a chain from the back end, I'd make something to fit between the ROPS standards behind the seat to protect the driver in case the chain snapped.
Basically, working with diesels is about the same as with gas engines. Diesels will use far less gas while idling for long periods though. Most important thing is to keep them revved up enough when working them. Keep that oil moving through those bearings and over hot surfaces, to both lubricate and to cool them.
   / Newbie quesstion Proper operation of Diesels #15
It is very interesting that such a small concentration of biodiesel will act as lubricant (Penn St article). I think that I will buy some Biodiesel to use as an additive.
Marshall
Wow, I get back from work and have all sorts of good info, thanks everybody.
To explain a little farther so you folks don't think I am putting my wife in jeopardy:eek: , I am pulling from below the rear axle using the drawbar mounting hole by attaching a clevis to the end of the drawbar. We do have the rear blade on and lowered until it is only about an inch above the chain. That way if the chain were to break the rear blade would take the brunt of it.
The chain is 5/16 inch thick links so this is seriously overkill. The reason I ended up using the chain is that we have a lot of lava out here and the rock will start cutting a rope pretty quickly. I thought about using a strap Homebrew2 but thought the strap would fray just like the rope.
Mars1952 next time I do this we will load up the front bucket with some rocks, we sure have rocks handy. Come to think of it I may just pick up a few weights, the bracket is already on the tractor. I do need to check the manual and see what my idle is supposed to be and lower it to specks, the tractor has about 30 hrs on it so that should be enough of a "break in" don't you think?
Again, thanks everybody for the good advice. I don't post here very often but I sure am learning a lot reading.
   / Newbie quesstion Proper operation of Diesels #17
Careful about using straps, ropes or wire cable.
You are using chain because of cutting concerns but chain also does NOT stretch and store energy (i.e. rubber band) which is very good & what you want for safety.
However straps, ropes or cables when they break or come free can do lots of damage depending on how much energy is stored & the driver is right in the line of fire. How much damage? Anything from a sting to being cut in half!
Good luck & keep others away when applying a strain to any strap, rope cable or chain.
   / Newbie quesstion Proper operation of Diesels #18
"the tractor has about 30 hrs on it so that should be enough of a "break in" don't you think?"
No...I'd stick with the 50 hour break in duration, especially for the oil change. My dealer told me it's better to go beyond the 50 hours for break in (within reason...60 hours or so) then less.
"You are using chain because of cutting concerns but chain also does NOT stretch and store energy (i.e. rubber band) which is very good & what you want for safety.
You are using chain because of cutting concerns but chain also does NOT stretch and store energy (i.e. rubber band) which is very good & what you want for safety."
Good points! But even though the chain doesn't stretch as much, there's still a strong potential to spring back if it parts. Prehaps not as much as wire rope (nasty stuff, IMHO), but enough to do some damage.
I'd read a long time ago about getting an old fire hose (try your local fire hall) to sleeve your chain to reduce the any spring back if the chain parts. I've never had a chain part, so I can't document the validity, but it sounds right. Getting a dry rotted hose (try 1½" or 2") from your local fire dept. shouldn't be too difficult (especially if it's a volunteer dept.).
"It is very interesting that such a small concentration of biodiesel will act as lubricant (Penn St article). I think that I will buy some Biodiesel to use as an additive.
Marshall"
I'm not sure how big a deal this would be with CUT's considering the relatively low hours we put on these machines. That article and the links provided did give me an insight to the problem and potential solutions. I'm going to look into an additive (probably Stanadyne).
If I used biodiesel as an additive, I wonder how much one would have to use, and how frequently?
   / Newbie quesstion Proper operation of Diesels #19
RoyJackson: I like this idea and I am going to try to get some fire hose.
Marshall"
RoyJackson: The article states "Using just a B1 blend (1 percent biodiesel with 99 percent regular diesel fuel) improves lubricity of ultra-low-sulfur diesel fuel by as much as 65 percent."(This is from the Penn St link) Biodiesel is cheap per gallon compared to any additive. It would probably be cheaper to use straight biodiesel instead of regular diesel plus an additive. I think that I will add as much as 5% biodiesel to my fuel or maybe switch over to 100% biodiesel. Here in the Asheville area Biodiesel is readily available.
Here is a link about biodiesel lubricity
Here is a link to Biodiesel.org
Good Luck, Marshall
   / Newbie quesstion Proper operation of Diesels #20
Mars1952:
I would not recommend running B100 in a tractor especially in cold weather. NH recommends up to B20 only. I had enough trouble with diesel gelling with ULSD this winter when temperatures dropped into the teens and moreso when the temperatures dropped into the single digits or lower. People running biodiesel had even more difficulties. I used a "double shot" of Power Service (white bottle) to manage my gelling challenges as well as increase the "lubricity" of my ULSD. Another thing to consider is that both ULSD and bioddiesel tend to "lift" the sediment/junk/residue in your tank and fuel lines which can lead to fuel line, injector, and fuel filter clogs. Tractors do not like gelling and/or fuel line clogs :eek:. I would suggest that you check the numerous threads in the TBN Fuel & Lubricants Forum especially those posts by DieselPower (I apologize to the other informed contributors :( and would have referenced you guys as well, but I am not home and operating off someone else's computer.). I would also advise caution when attaching anything to your drawbar. Jay
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
Misc. Tools (A47477)
Pull-Behind Reel Mower Tractor Attachment (A55851)
Pull-Behind Reel...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2015 International DuraStar 4300 26ft. Box Truck (A55852)
2015 International...
