Newbie needs some advice
/ Newbie needs some advice #1
asetech
Hi guys,
I tried doing a search but could not find much. I am new to all of this stuff so please forgive my ignorance. I recently moved to NC. I have a house on roughly 10 acres of what used to be farm land. I got me a JD 4410 with a 5ft brush hog and mowed down the whole thing down. It is completly flat area but a very bumpy ride while brush hogging. I need some suggestions to fix that. Would I use a box scraper or possibly a landscape rake? I have no plans to seed any areas I just need to smooth out the ride so to speak.
Thanks.
/ Newbie needs some advice #2
If it is grassed.. and it is bumpy.. I'm afriad the best way to smooth it is to disc the heck out of it... Disc one direction.. then cross disc.. might use a chain matt to drag, and /or even a lawn roller or telephone pole section..
If it was a limited area.. you could spread a few inches of soil and let the grass come thru.. or if it was not grassed.. box scraper would be a great idea.
In most cases.. weeds and native grass will survive a discing.. multiple sucessive discings will thin the vegitation.
Soundguy
/ Newbie needs some advice #3
</font><font color="blue" class="small">( multiple sucessive discings will thin the vegitation.
)</font>
The grass is too thick in my yard.
Are you saying this will thin it out.
It is so thick in places I can't hardly mow it.
It even bogs down the 8N with the rotary cutter on it.
Pooh Bear
/ Newbie needs some advice #4
I have a 3/4 acre area that once had very thick lawn on it, (weeds, etc.). About once a month I thin it with my disc by going over it with successive diskings, guess what, that definitely does thin it out, in fact it does such a good job that I no longer have to spend 30 minutes to an hour mowing it every few weeks. It also helps get rid of the bumpy spots if I run my drag over it a few times.
Farwell
/ Newbie needs some advice #5
Pooh:
Yes.. discing lawn will thin it.. and if it bogs yer tractor down.. you need to mow it more often, or take smaller bites.
Soundguy
/ Newbie needs some advice #6
<font color="blue"> you need to mow it more often, or take smaller bites. </font>
Bigger tractor? /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/blush.gif
/ Newbie needs some advice #7
Last time I mowed I let it get away from me a bit.
Had to cut most of it with the bush hog.
And had a couple of spots that it bogged down.
This is the thickest grass I have ever seen.
And it just keeps getting healthier this year.
I need to do something to thin it out soon.
I'm thinking a light spraying with Round Up.
Pooh Bear
/ Newbie needs some advice #8
If you use Round Up on it, that will kill all of it.
You could mow it more often.
(or)
You could mow it twice, one time about 12 - 18", then come back for a second round and mow it at the height that you want it.
/ Newbie needs some advice #9
I don't think the problem is it getting too high.
It is just too thick. Too dense.
I mow it about ever week and a half or 2 weeks.
At about 10 days I can mow it but it is thick in places.
At 2 weeks I have to use the bush hog on most of it.
I never seen grass like this before.
Round Up......Kill all of it.......Hmmmm...........
Don't tempt me like that.
Pooh Bear
Sound guy,
It sounds like there is no easy solution to my situation. Do you think a powered landscape rake may work for me? I realize it will churn everything up but it looks like it may smooth the whole thing out and I am sure that it will come back green afterwards. If so do you have any idea how much one may go for? I see quite a few manufactures on the internet but no one has a price (That probably means expensive /forums/images/graemlins/tongue.gif).
Thanks
/ Newbie needs some advice #11
I mowed most of the yard today.
I didn't let it get too high this time.
Still had to mow in first gear cause it was so thick.
Starting to really wish I had some haying equipment sized for the N.
Pooh Bear
/ Newbie needs some advice #12
</font><font color="blue" class="small">( you need to mow it more often, or take smaller bites.
Bigger tractor? )</font>
Worked for me!!!
Soundguy
/ Newbie needs some advice #13
</font><font color="blue" class="small">( Do you think a powered landscape rake may work for me )</font>
I wouldn't -think- it would work well in that situation... IMHO..
Soundguy
JOHN DEERE HX14 ROTARY MOWER, 3PT (A64278)
JOHN DEERE HX14...
2015 John Deere CX15 (A64126)
2015 John Deere...
2015 Kawasaki Prairie 400 ATV (A64557)
2015 Kawasaki...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
2025 Auger Bit Skid Steer Attachment (A64553)
2025 Auger Bit...
2002 Harmon Steel Barrel Asphalt Tanker Trailer (A64194)
2002 Harmon Steel...
