Newbie needs help
   / Newbie needs help #1
jerrywtrull
Moultrie, Ga
63 Ford 4000 4 cyl diesel
I have a ford 4000 4 cyl diesel tractor( not sure about the year) that was running fine. I was mowing for 3 hrs and parked it for the night and it has never started again. It acts like it is not getting any fuel.
Any ideas?
   / Newbie needs help #2
Welcome from Wisconsin there are Experts on fords here they will be helping you.
   / Newbie needs help #3
Jerry...check your fuel filter...it well could be clogged...from what you say I guess it is turning over but just won't crank...Fuel filter is the first thing I would check...Others will have advice...stay tuned...Welcome...
   / Newbie needs help
Thanks for such a quick response, I have replaced the fuel filter, also I am getting fuel to the injector pump but none to the injectors. Is it possible the injector pump went out so easy? It does not have a stop cable, you just push the throttle lever all the way up to shut off.
   / Newbie needs help #5
Is it making any smoke as you crank it?
   / Newbie needs help
no smoke, the engine just turns over. I even tried a small amount of starting fluid and no results. I had a guy tell me there may be a throttle needle stuck in the injector pump, is that possible?
   / Newbie needs help #7
gov ring may be bad.. ..
try getting a pull start for the heck of it though.. it may just have not bleed yet. them roosamaster bleed hard I hear.
   / Newbie needs help #8
My old MF30 diesel backhoe used to require a squirt of starting fluid every time. Had to carry a can in the toolbox. Maybe try a squirt in the air cleaner, can't hurt.
   / Newbie needs help
Thanks guys for your input but nothing works. I pulled it around for a while and it did not even try. I tried more starting fluid and it does not even try to start. I has compression and is in time. I am out of ideas.
   / Newbie needs help #10
you say it has compression... yet does not even 'try' on start fluid.
I got news for you. if it does not pop on start fluid. it either has stuck intake valves , blocked air intake, or no compression ( too low of compression for heat of combustion to occur )
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
