Newbie needs help with tractor ID
/ Newbie needs help with tractor ID #1
Tntneave
Oakdale
TS2202f
I bought an Iseki tractor yesterday from a nice older couple who didn稚 use much and really didn稚 know much about the tractor. They told me the model was a TS2202f. When I got home and started researching parts and service manuals I found that the TS2202 is a 3cylinder. I am no mechanic but when I open the hood there appears to only be 2 pistons on the block. So unless Iseki designed an engine with the third cylinder under the engine block which I haven稚 found I am guessing they had the wrong model number. After scouring this forum and TractorData.com it looks like the TS**10 tractors are 2 cylinder tractors. Does anyone have any suggestions on how I can determine what model Iseki I bought?? I really want get the manuals and filters so I can service it before I put her to use.
Thanks in advance for any help and/or suggestions.
Tad
/ Newbie needs help with tractor ID #3
First off welcome to TBN.
I couldn't open your attachment. :(
/ Newbie needs help with tractor ID #4
I could not open the photos either. Personally, I would not let the fact that you have a 2 cylinder bother me. If it is anything like my 2 cylinder Shibaura/Ford, you will find it to be torquey and a real fuel miser.
/ Newbie needs help with tractor ID #5
Lots of pics on the web. If it's what they say it is, Very nice tractor.
/ Newbie needs help with tractor ID #6
Check the wheelbase. If it's a 2 cyl diesel with a 61.5 in wheelbase its mostly likely (almost certainly) TS2210. If the wheelbase is in the 54 in range its either a TS1910 or TS1610.
/ Newbie needs help with tractor ID #7
You can also check the model number of the engine. That will be on the lower right side, if you're facing the tractor. The table I have in the manual for TS**10 series shows:
2AA1 goes with TS1610 and TS1910
2AB1 goes with TS2210 and TS2510
3AA1 goes with TS2810
3AB1 goes with TS3510
The first digit indicates whether it is a 2 or 3 cylinder.
84in. Snow or Litter Skid Steer Bucket (A65640)
84in. Snow or...
60 Traffic Cones (A65579)
60 Traffic Cones...
2014 Toyota Tundra Crew Cab Pickup Truck (A64194)
2014 Toyota Tundra...
Freightliner Columbia (A63689)
Freightliner...
MechMaxx Grinder Betsco Flail mower
MechMaxx Grinder...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
