Newbie mf 135 owner
   / Newbie mf 135 owner #1
yuridog
Bonners Ferry, Idaho
mf 135 contenintal z134
Anyone know how to adjust a carb on a MF 135 continental z134 4 cyl gas engine?
Thanks
   / Newbie mf 135 owner #3
Welcome to TBN :)
I moved your thread to the Massey Ferguson Owning/Operating Forum.
1967 mf 135 deluxe with the marvel-Scribner carb ( Continental z-134, 4 cylinder gas engine).
I have checked the timing & it is at 5 degree...points are set right 21 & good condition....plugs/wires & distributor are good. I use non ethanol premium gas.
The carb has an idle air/gas screw with a spring around it & a larger gas/air mixture screw. I am not a mechanic, however, I try to take care of my baby myself....Don't trust anyone else with her...LOL
I am having a difficult time try to get her to run & idle smoothly...
Thanks very much for your help!!! I hope this helps you.
Dennis
   / Newbie mf 135 owner #6
Dennis
Welcome to TBN-join the fun:thumbsup:
It's Marvel Schebler. Find the carb number and then google it. You should find the info you need.
   / Newbie mf 135 owner #7
Before adjusting the carburetor, you should verify that you have a good spark. Have you checked/replaced the condenser? They can cause the tractor to run rough and have idle problems. It's less likely, but the coil can sometimes do the same.
Thank you very much & I'll go out & check the condenser. I really do appreciate all the help!! I am trying to figure out how to upload my photos as we speak....thanks to all!!!
Thanks much!!!!!
How in the heck does one post a photo with your name?
Dennis
   / Newbie mf 135 owner #10
Are you sure its a Z-134?? I've got a '67 135 Delux (all five gauges) with the Z-145 Cont..do you still have the plate on the left side of the engine?? BobG in VA
2016 Ranger 570 EFI (A52384)
2016 Ranger 570...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
2014 Ford Escape SUV (A51694)
2014 Ford Escape...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
