Newbie mf 135 owner
   / Newbie mf 135 owner #1
yuridog
Bonners Ferry, Idaho
mf 135 contenintal z134
Anyone know how to adjust a carb on a MF 135 continental z134 4 cyl gas engine?
   / Newbie mf 135 owner #3
Welcome to TBN :)
I moved your thread to the Massey Ferguson Owning/Operating Forum.
1967 mf 135 deluxe with the marvel-Scribner carb ( Continental z-134, 4 cylinder gas engine).
I have checked the timing & it is at 5 degree...points are set right 21 & good condition....plugs/wires & distributor are good. I use non ethanol premium gas.
The carb has an idle air/gas screw with a spring around it & a larger gas/air mixture screw. I am not a mechanic, however, I try to take care of my baby myself....Don't trust anyone else with her...LOL
I am having a difficult time try to get her to run & idle smoothly...
Thanks very much for your help!!! I hope this helps you.
Dennis
   / Newbie mf 135 owner #6
Dennis
Welcome to TBN-join the fun:thumbsup:
It's Marvel Schebler. Find the carb number and then google it. You should find the info you need.
   / Newbie mf 135 owner #7
Before adjusting the carburetor, you should verify that you have a good spark. Have you checked/replaced the condenser? They can cause the tractor to run rough and have idle problems. It's less likely, but the coil can sometimes do the same.
Thank you very much & I'll go out & check the condenser. I really do appreciate all the help!! I am trying to figure out how to upload my photos as we speak....thanks to all!!!
Thanks much!!!!!
How in the heck does one post a photo with your name?
Dennis
   / Newbie mf 135 owner #10
Are you sure its a Z-134?? I've got a '67 135 Delux (all five gauges) with the Z-145 Cont..do you still have the plate on the left side of the engine?? BobG in VA
2019 John Deere 3025E (A50123)
2019 John Deere...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
70003 (A51691)
70003 (A51691)
2020 Ottawa T2 Spotter Truck (A52384)
2020 Ottawa T2...
Hand Truck (A52377)
Hand Truck (A52377)
Frontier GM1084 (A50123)
Frontier GM1084...
