New YT235C Loader Hydraulic Leaks
   / New YT235C Loader Hydraulic Leaks #1
Gypsyman
Quincy, FL
2020 Yanmar YT235C
After months of waiting and a comedy of errors on the dealers part I finally have the YL310 front end loader and 3rd function kit installed. After fixing all of the hose routing issues (due to a terrible installation) I parked the tractor assuming it was ready to go. I came out a few days later to find a puddle of hydraulic fluid under the quick connect fittings. I cleaned everything up and threw a drip pan under it. Two days later I came out to find a puddle under the QA fittings again.
Is this common with the Yanmar fittings? They don't leak under pressure but if I push the hoses to the side at all when the tractor isn't running I can see hydraulic fluid seep out of the fittings. They seem very sloppy for QA fittings. Due to this I can't secure the hoses the way that they should be because the zip ties pull the hoses to the side and make the leaks even worse. The fittings on my old 2006 Kubota B3030 FEL have never leaked a drop, even if I force them sideways.
Considering what the loader cost (and the 6 month wait time) if I have to replace all of the QA fittings on a brand new FEL to get rid of the constant drips I'm going to be pretty annoyed. Don't even get me started on the poor dealer install. :LOL:
Thoughts? Solutions?
   / New YT235C Loader Hydraulic Leaks #2
Which 3rd function did you have installed?
I asked for the Yanmar kit when I ordered it not knowing that Yanmar didn’t actually build their own third function kits. It ended up being the W.R. Long kit.
It's ok but more of a universal kit in my opinion. The control handle leaves a lot to be desired. It sit too high but I'll correct that by shortening the joystick lever an inch or two. The set bolts stick out and irritate your hand if you hold the control handle by the side instead of the top. Should be able to remedy that by swapping the retaining bolts to allen head set screws so that they sit flush. I need to spend a little more time on the hose routing from the back to the front. The hoses sit far too close to the tire for my taste.
   / New YT235C Loader Hydraulic Leaks #4
Yanmar does have their own kit, P/N TVK-YL310P. Can you show a pic of where it is leaking?
That's what I ordered and what I was billed for. The kit came from Yanmar with the loader, new front wheels, and the rear light kit. When they handed me the installation and owners manual it was the WR Long kit.
The fluid is coming from inside the quick connectors. If you just wiggle them back and forth you get a constant drip. In the second photo you can see by the mating lines how loose they are and see a fresh drop of fluid hanging from the bottom of the connector.
I have a feeling that I will be forced to change the connector pairs out for Parker or some other higher quality units. I seriously doubt that I will hear back from Yanmar on this.
   / New YT235C Loader Hydraulic Leaks #6
WR Long is not a Yanmar kit. The fittings you have are not compatible with the tractor. The fitting style is ISO 5675 on the tractor.
The third function kit is just fine. It’s the factory quick attach connectors from the tractor to the factory loader that are leaking.
Cushman Electric Cart (A55851)
Cushman Electric...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
New/Unused CFG Industrial MX15RX Mini Excavator (A57453)
New/Unused CFG...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
SET OF PRECAST STEPS (A58374)
SET OF PRECAST...
JOHN DEERE 920 FLEX GRAIN HEAD (A52708)
JOHN DEERE 920...
