New Woods 72 Brushbull shimmies
   / New Woods 72 Brushbull shimmies #1
gsholz
Sherwood
Kioti DK45SE HST
I used our new 6 foot Woods flail mower for the first time and noticed a very pronounced shimmy right from the start. It is a new unit. I expected operation to be smoother. Unfortunately, the dealer is 70 miles away. I was planning to mount it back on the tractor, lift it and check blades for free movement. Should I take the blades off and weigh them? Other ideas?
   / New Woods 72 Brushbull shimmies #2
Is it only at start up? If so then it's normal. The blades need to straighten out since they are free swiveling and require centrifugal force to straighten out (spinning). You should always start the cutter at idle to help this out. If it is still shaking after it's up to speed then something is out of balance or bent.
   / New Woods 72 Brushbull shimmies #3
^ What Mike said - start cutter at idle & engage PTO s-l-o-w-l-y, if that's possible. Quick engagement can snap the blades back, where they may bind and remain. My blades get harder to swivel the further they get from being straight, making them resist straightening until RPMs are higher or I mow something substantial ...
   / New Woods 72 Brushbull shimmies #4
Flail or rotary cutter?
   / New Woods 72 Brushbull shimmies #5
Sounds as though some of the blades may be stuck in the non-extended position. If its new you certainly would not expect bent blades. It does sound like something is definitely out of balance.
   / New Woods 72 Brushbull shimmies #6
Rotary, Brushbull isn't a flail mower.
2020 Terex RL4 Towable Light Tower (A51691)
2020 Terex RL4...
480/70R38 LOT NUMBER 135 (A53084)
480/70R38 LOT...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
2025 New/Unused Wolverine 72in Skid Steer Hydraulic Rotary Tiller (A51573)
2025 New/Unused...
2 Disc Heavy Duty Bottom Plow (A51573)
2 Disc Heavy Duty...
