New version of Pat's Easy Change
   / New version of Pat's Easy Change #81
Re: Pat\'s Easy Change & PHD
Someone on here mentioned the fact that most of the hardware that coms with the PEC is not really needed. I found this to be true. I dont have the "u" bolts on nor do I have the adjustors on any longer. 1 carter key, knock out the large "axle" and it comes off, easy on too!
found that it makes it easier to get stuff hooked up, and it will now move around more so I dont have too
   / New version of Pat's Easy Change #82
The hardware that holds the U-bolt down vibrated loose while using my blade... I decided to keep the U-bolts on and just used locking hardware (nylon lock nut) that I bought at a hardware store for a couple of bucks.
If I lose that hardware over time then maybe I take your advice and just drop the U-bolt... time will tell.
2013 Ford Edge (A54815)
2013 Ford Edge...
JOHN DEERE 850K LGP CRAWLER DOZER (A52707)
JOHN DEERE 850K...
2015 Ford Taurus AWD Sedan (A55853)
2015 Ford Taurus...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
Hustler 60in Zero Turn Mower (A55851)
Hustler 60in Zero...
Year: 2015 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A56859)
Year: 2015 Make...
