New version of Pat's Easy Change
   / New version of Pat's Easy Change #81
Re: Pat\'s Easy Change & PHD
Someone on here mentioned the fact that most of the hardware that coms with the PEC is not really needed. I found this to be true. I dont have the "u" bolts on nor do I have the adjustors on any longer. 1 carter key, knock out the large "axle" and it comes off, easy on too!
found that it makes it easier to get stuff hooked up, and it will now move around more so I dont have too
   / New version of Pat's Easy Change #82
The hardware that holds the U-bolt down vibrated loose while using my blade... I decided to keep the U-bolts on and just used locking hardware (nylon lock nut) that I bought at a hardware store for a couple of bucks.
If I lose that hardware over time then maybe I take your advice and just drop the U-bolt... time will tell.
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2012 Mazada 3 Sedan (A55853)
2012 Mazada 3...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
greenworks (A53421)
greenworks (A53421)
2024 78in Hydraulic Brush Grapple Skid Steer Attachment (A55851)
2024 78in...
