New Vehicle Undercoating
/ New Vehicle Undercoating #1
ProjectKing
Platinum Member
USA
Kubota L3830 FEL, Kubota L3301 FEL/BH, Ford Golden Jubilee, Honda Foreman 450ES, Polaris Ranger 400, Kubota ZD326, etc, etc
Hello, Considering buying a new Toyota 4Runner. What is everyone’s opinion on undercoating? Vehicle will driven in some salt during the winters.
I’m interested in some sort of DIY product. Maybe Fluid Film? I would like to spray the new vehicle as well as my older truck, etc.
Any input would be very welcome. Thank you!!
/ New Vehicle Undercoating #2
I've had undercoated and rust proofed cars and trucks for many years. I found the biggest problems are in the hidden pockets of the body, and the frame area where most coating was used didn't matter in the long run. I used Fluid Film as a complete underbody, frame, hidden pocket spray starting about 6 years ago. I found the frame spray wears off quick anyway, and decided to leave that area alone when I reapplied each fall. For the past 3 years I've settled on a simple routine in late fall. I use a couple simple aerosol cans of Fluid Film which is enough for 3 vehicles. I fog/spray some inside each door, tailgate, and along rocker panel areas that are entrapped. Any area where you've seen cars or trucks with rust is where I focus. I mainly use existing holes or plugs to get the straw inside and spray for a few seconds. That's it. FF creeps into the nooks and crannies and lasts a long time in those hidden pockets, which are the most important up here in the rust belt. If I don't wash my truck I will see the oil film gradually creeping out and around the outside painted areas, even a year later.
/ New Vehicle Undercoating #3
Toyota had frame rust issues in the late 1990s and early 2000s. I’m guessing they are going overboard on the undercoating and steel quality now. I’d skip the dealer undercoating. Spend the money on a car wash that does an undercarriage wash.
/ New Vehicle Undercoating #4
I have found anything a dealer supplies you can get done by a specialist for at least half the price, tints are a good example, dealer had a 'special' at $800, we paid $270 at a tint and windscreen shop.
/ New Vehicle Undercoating #5
If you can find a shop that applies it; check out waxoly I have it on my truck and am pleased so far.
They should be using two different products, one is used in the doors and channels and a heavier one on exposed surfaces.
I had my RAM done in "15" and it still looks very good on the entire underside of the truck.
It is getting thin in a few spots I think I'll take it in next summer for a touchup and reapplication.
Waxoyl USA | Offering 36o of Protection from Corrosion.
2020 INTERNATIONAL MV607 (A63569)
2020 INTERNATIONAL...
2012 VANTAGE TRAILER PMEUMATIC CEMENT TRANSPORT TRAILER (A63569)
2012 VANTAGE...
2021 KUBOTA SVL75-2 SKID STEER (A64279)
2021 KUBOTA...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
