New TYM (Branson) 5520C
   / New TYM (Branson) 5520C #11
Op,
Just run it. No worries about "break in". Does yours have the regen button on the dash? Newer Bransons did, older ones did not.
   / New TYM (Branson) 5520C #12
Yes, make sure you idle machine for a minute or two before shut off, to let turbo cool off.
I would expect that it is also getting a bit more fuel along with the turbo to make the hp.
She'd be a smokey thing without the turbo. As has been said turbos are quite reliable,
give them a minute or two to cool after being worked and good oil they work for a long time.
   / New TYM (Branson) 5520C #13
Turbo engine Might also include better, tougher, pistons with steel ring inserts.
   / New TYM (Branson) 5520C #14
I didnt really break my tractor in. It had a total of three hours on it before it was tasked with 12 hours of tilling virgin ground at a constant 2600rpm.
   / New TYM (Branson) 5520C #15
The manual says 5520CH (3.9 gal / hr) uses 30% more fuel than 4820CH (3.0 gal / hr). Isn't turbo supposed to be more fuel efficient?
   / New TYM (Branson) 5520C #16
Takes fuel to make HP. If not needing all the HP it will use less fuel.
   / New TYM (Branson) 5520C #17
I definitely don't burn 3gal/hr on my 4820.
It burns much less typically
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
John Deere 1600 Turbo Series II (A57453)
John Deere 1600...
16ft Driveway Entrance Gate with Tree of Life Design (A57454)
16ft Driveway...
New/Unused Electric 3-Wheeler (A57453)
New/Unused...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
