New trailer
/ New trailer #21
I found a simular trailer at T.S for 2.5K is this a good or comparible price?
for the Brake controller, on my Boat trailers I have the trailer brakes that are controlled by actuator, is this the same for these type trailers?
/ New trailer #22
Are you talking surge brakes where the controller is on the tongue of the trailer and pressure is applied by the vehicle slowing down? If so, no. We are talking about a little electronic box that sends an electric signal via a wire to the trailer to apply the magnetic brakes.
/ New trailer #23
Thanks. Yes that is what I was talking about. I was wondering if they made such a thing for this type trailer.
/ New trailer #24
I've heard of utility trailers (Uhaul) having surge brakes, but most I know are electric as they work so much nicer/smoother/better. As far as converting over to a surge system, I'm sure it could be done, but I would bet it would be pretty expensive. I think surge brakes are a different type of system in that they actually apply fluid pressure (similar to how a car does) to the brakes. Hopefully someone that knows better than I do for sure.
/ New trailer
I paid 2500 for mine out the door tax title license everything.
Looks like this brake controller will be a little bit of a pain to install but the nice thing is it's a one time deal than i'm good to go.
Thanks fro the links and help I'll print out that PDF you linked me too that has the walk through on how to install it. I'll report back on how it went after the weekend.
/ New trailer #26
BR,
BTW, Chris, I did stop at Radio Shack last night and picked up mostof the stuff (LEDs, switchs, and project boxes) to build a testers for the truck & trailer wirings. I had picked the ends up a couple of weeks ago at Menards. Now I just need to get some wire for the truck side tester.
Just send the royalty checks my way!;)
Use mine at least once a week. I also make one with 6 lights and the male plug to test the vehicle side. Just plug it in the rear of the truck and it has 20' of wire so I can sit in the the driver seat and go through the checks. Use it even more.
Chris
/ New trailer #27
Can I do this for my 07 RAM 1500?
/ New trailer #28
Chris
I'm building both. Using LEDs for the truck side so I can use one of the small Radio Shack Project boxes as well.
/ New trailer #31
I see where they have one with the 7 pin round, but not the 7 pin blade RV style. I also don't like the fact that the lights are at the back of the truck. With some wire, I can run all of my tests without walking to the back of the truck for each test. Besides, it is probably more expensive than what I'll have wrapped up in mine.
Thanks for the tip though.
/ New trailer #33
I used light bulbs because I was not sure if the LED's would work without a resistor? Pretty good with electrical stuff but not the best so I went the safe route. I did put a 10 amp fuse on the truck side tester. Put the fuse in line with the negative lead going to all 6 test lights.
Chris
/ New trailer #34
Look what I just found. This would be ideal. Too bad it isn't in stock:
RV Electrical Tester, Simulates Towing Light Setups
Might have to look around to see if I can find one somewhere before I start building my own.
WOW!!! I just found that sucker at another site for almost $500. So for $23.08, it would be mine.
Yes I built one for the trailer and one for the truck for under $40 total. They do what I want and work the way I want them too and it was a fun project.
Chris
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2012 John Deere 6430 102HP Agricultural 4WD Tractor (A61572)
2012 John Deere...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
Great Dane Van Trailer 1989 (A63689)
Great Dane Van...
2012 International Prostar (A63118)
2012 International...
