New Tractor
/ New Tractor #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
Buying either a John Deere 5060E with cab or Kubota MX5400 with cab..Will be used primarily for heavy shredding with 6' or 7' cutter. Will not get a lot of use..Suggestions??? Thanks!
/ New Tractor #2
Whichever tractor, build a heavy duty expanded metal rear window protector. Trust me, you'll not regret it.
/ New Tractor #3
T-B-N ARCHIVE:
/ New Tractor #4
I thought the MX was kinda like a large L series. Smaller than a M tractor. Just like a BX is smaller than a B series. Not sure those two tractors are really even comparison in weight and capability.
I would compare the larger L series Kubotas to the 4000 series JD. I always thought that a true M series Kubota would be comparable to a 5000 series JD.
/ New Tractor
/ New Tractor
The John Deere has no regen and the Kubota has regen but no DEF..Is that a consideration?
/ New Tractor #7
Like all the X series Kubotas, the MX is sized to be a crossover between the M and L series, so in-between.
/ New Tractor #9
Or get a chain guard kit for the mower. Haven’t had anything kick up enough to damage back of cab.
/ New Tractor #10
Looks to me like the JD is about 10 HP more and 2500 pounds more. Quite a difference really.
THIS ^^^
That much weight creates a huge gain in traction. Frame strength/durability will be better.
/ New Tractor #11
That's a whole lot of tractor for only a 6' cutter.
Why such a small mower?
/ New Tractor #12
T-B-N ARCHIVE:
I still don't know where you get some of your "facts" Jeff.
And you keep re quoting them.
/ New Tractor #13
He said occasional use... so a lighter duty tractor and cutter may suit his needs without putting him in the poor house... just a thought.
/ New Tractor #14
I've noticed that my MX5200 feels significantly more stable on hillsides with my 6' cutter than the same cutter felt on my previous 35hp Mahindra. I was sort of thinking about buying a larger cutter, but I'm liking the increased stability so much I'm not sure I want a larger cutter.
I wasn't sure from the original post what the OP really wanted to know, however.
/ New Tractor #15
Kubota equivalent would be a M6060, but the Deere still heavier and out specs it a little in hydraulics.
/ New Tractor #16
And it really depends on what is being cut. A light duty cutter is more than adequate for grass; not good for brush or saplings.
/ New Tractor
I have access to a 6'and 10' cutter but I did not think either machine would handle the 10' heavy duty Bush Hog..
/ New Tractor
Really asking if one is more reliable and trouble free than the other
/ New Tractor #19
The MX5400 on the 10’ would be a no. The Deere would be fine with it.
/ New Tractor #20
Have you looked at the Deutz 5080D???
quite the machine
willy
HARDEE 5' ROTARY MOWER (A63291)
HARDEE 5' ROTARY...
2010 Workhorse Custom Chassis W62 Delivery Truck with Liftgate (A61573)
2010 Workhorse...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
