New Tractor
/ New Tractor #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
Buying either a John Deere 5060E with cab or Kubota MX5400 with cab..Will be used primarily for heavy shredding with 6' or 7' cutter. Will not get a lot of use..Suggestions??? Thanks!
/ New Tractor #2
Whichever tractor, build a heavy duty expanded metal rear window protector. Trust me, you'll not regret it.
/ New Tractor #3
T-B-N ARCHIVE:
/ New Tractor #4
I thought the MX was kinda like a large L series. Smaller than a M tractor. Just like a BX is smaller than a B series. Not sure those two tractors are really even comparison in weight and capability.
I would compare the larger L series Kubotas to the 4000 series JD. I always thought that a true M series Kubota would be comparable to a 5000 series JD.
/ New Tractor
/ New Tractor
The John Deere has no regen and the Kubota has regen but no DEF..Is that a consideration?
/ New Tractor #7
Like all the X series Kubotas, the MX is sized to be a crossover between the M and L series, so in-between.
/ New Tractor #9
Or get a chain guard kit for the mower. Haven’t had anything kick up enough to damage back of cab.
/ New Tractor #10
Looks to me like the JD is about 10 HP more and 2500 pounds more. Quite a difference really.
THIS ^^^
That much weight creates a huge gain in traction. Frame strength/durability will be better.
/ New Tractor #11
That's a whole lot of tractor for only a 6' cutter.
Why such a small mower?
/ New Tractor #12
T-B-N ARCHIVE:
I still don't know where you get some of your "facts" Jeff.
And you keep re quoting them.
/ New Tractor #13
He said occasional use... so a lighter duty tractor and cutter may suit his needs without putting him in the poor house... just a thought.
/ New Tractor #14
I've noticed that my MX5200 feels significantly more stable on hillsides with my 6' cutter than the same cutter felt on my previous 35hp Mahindra. I was sort of thinking about buying a larger cutter, but I'm liking the increased stability so much I'm not sure I want a larger cutter.
I wasn't sure from the original post what the OP really wanted to know, however.
/ New Tractor #15
Kubota equivalent would be a M6060, but the Deere still heavier and out specs it a little in hydraulics.
/ New Tractor #16
And it really depends on what is being cut. A light duty cutter is more than adequate for grass; not good for brush or saplings.
/ New Tractor
I have access to a 6'and 10' cutter but I did not think either machine would handle the 10' heavy duty Bush Hog..
/ New Tractor
Really asking if one is more reliable and trouble free than the other
/ New Tractor #19
The MX5400 on the 10’ would be a no. The Deere would be fine with it.
/ New Tractor #20
Have you looked at the Deutz 5080D???
quite the machine
willy
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
1999 22ft Sea Ray Boat w/ 2015 23ft Shorelander T/A Boat Trailer (A61574)
1999 22ft Sea Ray...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
(7) KUBOTA BRUSH GUARDS (A64280)
(7) KUBOTA BRUSH...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
