New tractor on Saturday
   / New tractor on Saturday #11
I am anxious to get it also, but it really makes me wonder with all the posts about what you can't do with these FEL's and tractors. CJ
Going to be one sleepless night tonight..:D
   / New tractor on Saturday #13
I don't recommend pulling/dragging heavy loads in reverse using the loader. (Use the drawbar on the back of the tractor for pulling, thats what its there for.)
And don't use your loader as a battering ram.
Other than that just use the loader, it will be fine.
   / New tractor on Saturday #14
Almost forgot.
Use proper ballast of the rear of the tractor for loader work.
Helps keep the rear tires on the ground so the front axle isn't doing all the work and makes the tractor much more stable when lifting heavy loads.
Almost forgot.
Put 5 hours on it this week end, still too much snow for the backfill work that I need to do. I have the rear tires loaded and it is about right for counter ballast. Remember counter ballast only stops the back end from coming up, you still have the same load on the front. With more ballast you can pick up more and you will put more load on the front axle. The loader will not pick the backend of the tractor up lifting but it will curling or in roll back. In my opinion that is about perfect. I am really, really glad I got the 50HP using the loader in midrange you have to be aware of what you are doing so you don't stall the tractor. I know it will get better when it breaks in but I am still glad I got the 50. So far I am happy with the unit. I am used to running heavy equipment so this tractor has alot to live up to, so far it is doing well. CJ
   / New tractor on Saturday #16
congrats, where's the pictures???
Even if I had pics I am too computer retarded to post, besideds it is all dirty now!!! I'll get some. Heck you guys act more excited than I am. CJ
   / New tractor on Saturday #18
I want some pics please, i can only look at my tractor cause the ground is soooo wet i created ruts and got yelled at.:laughing:
1608 (A57192)
1608 (A57192)
CAT D8 (A58214)
CAT D8 (A58214)
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
2013 International Derrick Digger Truck (A55973)
2013 International...
Enerpac RCS302 30-Ton Hydraulic Jack, 5" Tall (A59076)
Enerpac RCS302...
2018 Chevrolet Silverado (A55973)
2018 Chevrolet...
