New tractor. Mahindra 2816 hst.
   / New tractor. Mahindra 2816 hst. #11
Interesting about the idle speeds, I've read the same in my manual, although mine is a gear, I've never paid much attention to my idle speed. I just drive like any other vehicle, such as a truck, when I mow or work the loader I usually dont let it get under 2000 rpms, just to keep the power up, but when just driving down the road in high range I probably run around 1500 to 2000, if going slow around the yard it may only run 1000 to 1500. I feel its easier on the clutch if you idle down when changing gears or directions, at least in my opinion.
My father-in-law is a retired desiel machanic and worked for catapillar and others, he said that engine is designed to run wide open all the time, daylight to dark. I just feel like I'm abusing my equipment running it like that. Who knows?? Just my 2 cents.
   / New tractor. Mahindra 2816 hst. #12
1500 RPM seems to be the magical number to run the tractor without a load, at least according to my manual. I'm usually somewhere between 1400 and 1500 when I start up the engine from cold and before I shut it down from being hot. I'm more concerned about the turbo overheating before shutdown than anything else. I recall some Yanmars suggesting you start at full throttle and then throttle down...seems a bit scary to me.:confused: As far as idle speed, I'm thinking that maybe the radiator fan is not spinning fast enough to draw enough air across it. The cooling system does a better job of maintaining the right temp if kept at 1500. Most loader and grading work I'm running between 1800 and 2000. Most pasture work no-till drilling, spreading lime/fertilizer I'm between 1800 and 2300 depending if I'm going down or up a grade. I'm more or less trying to maintain an even speed and being fuel efficient. When bush hogging I keep it at the PTO mark which is supposed to be 2376. Never really ran her higher than that. After close to 4 years of use, all seems good here.:D
2015 JOHN DEERE 5100M TRACTOR (A51243)
2015 JOHN DEERE...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
Informational Lot - Financing (A51039)
Informational Lot...
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
