new tractor "break in"
/ new tractor "break in" #1
Anonymous Poster
Epic Contributor
new tractor \"break in\"
I have a new Mahindra 35 HP. Any tips on proper "break in" procedures would be appreciated.
/ new tractor "break in" #2
Re: new tractor \"break in\"
What model do you have?
Re: new tractor
I have a model 3505 Mahibdra.
/ new tractor "break in" #4
Re: new tractor
I recently purchased a 4110 myself. Regarding the break-in, based on a search of other posts, there seems to be two approaches.
1) Use it like you "normally" will, that way if something breaks, it will break in the beginning. I don't think folks are advocating abuse, but instead just saying not to "baby it".
- or -
2) "baby it" and don't put it under heavy loads, stresses, & the such. Vary RPMs a lot, etc. Basically, don't "use" it until it has some hours on the meter.
I kindof took an approach somewhere in between. I've tried not to lug the engine (has happened a couple of times inadvertently), I've kept the RPMs below 2000 (PTO 540 is @ a higher tach rating than that), but I haven't just drove around the property either. I've done BB & FEL work with it. Basically, I've taken things kindof "slow", but I have used it. I've also tried to make sure I stick to the "warm up" & "cool down" recommendations in the owners manual. Not sure if I'm doing things the "right" way or not, but since the manual didn't say anything specific, I figured its a reasonable approach.
Re: new tractor
Thanks for the information. My manual says for the first 25 hours run at "half load" in low gears; for the next 25 hours run at "medium load" in low gears; after 50 hours and first oil change, tractor can be put to normal use.
So far I have only used mine to move some round hayt bales with a spear on the 3 point hitch. Plan to do some medium duty bush hogging next.
/ new tractor "break in" #6
Re: new tractor
Interesting.... I wonder what they mean when they say "half load" and "medium load"...? Do they give any examples?
I too have mostly used the low gears. Partly because I needed the power, partly because I didn't want to "mess up" since I'm new to this whole thing myself.
Re: new tractor
A little more info from the manual--half load-"with a trailer having gross weight of 2-3 metric tons on level road or for cultivative work in low gears." medium load--"pulling a trailer with gross weight of 4-5 metric tons on level road or harrowing/cultivation in low gears."
Kuhn FC400RG (A60462)
2022 Caterpillar 289D3 Rubber Track Skid Steer (A64047)
2022 Caterpillar...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
Spray Daddy 100 Gallon 30 Ft Sprayer (A64047)
Spray Daddy 100...
