new tractor "break in"
/ new tractor "break in" #1
Anonymous Poster
Epic Contributor
new tractor \"break in\"
I have a new Mahindra 35 HP. Any tips on proper "break in" procedures would be appreciated.
/ new tractor "break in" #2
Re: new tractor \"break in\"
What model do you have?
Re: new tractor
I have a model 3505 Mahibdra.
/ new tractor "break in" #4
Re: new tractor
I recently purchased a 4110 myself. Regarding the break-in, based on a search of other posts, there seems to be two approaches.
1) Use it like you "normally" will, that way if something breaks, it will break in the beginning. I don't think folks are advocating abuse, but instead just saying not to "baby it".
- or -
2) "baby it" and don't put it under heavy loads, stresses, & the such. Vary RPMs a lot, etc. Basically, don't "use" it until it has some hours on the meter.
I kindof took an approach somewhere in between. I've tried not to lug the engine (has happened a couple of times inadvertently), I've kept the RPMs below 2000 (PTO 540 is @ a higher tach rating than that), but I haven't just drove around the property either. I've done BB & FEL work with it. Basically, I've taken things kindof "slow", but I have used it. I've also tried to make sure I stick to the "warm up" & "cool down" recommendations in the owners manual. Not sure if I'm doing things the "right" way or not, but since the manual didn't say anything specific, I figured its a reasonable approach.
Re: new tractor
Thanks for the information. My manual says for the first 25 hours run at "half load" in low gears; for the next 25 hours run at "medium load" in low gears; after 50 hours and first oil change, tractor can be put to normal use.
So far I have only used mine to move some round hayt bales with a spear on the 3 point hitch. Plan to do some medium duty bush hogging next.
/ new tractor "break in" #6
Re: new tractor
Interesting.... I wonder what they mean when they say "half load" and "medium load"...? Do they give any examples?
I too have mostly used the low gears. Partly because I needed the power, partly because I didn't want to "mess up" since I'm new to this whole thing myself.
Re: new tractor
A little more info from the manual--half load-"with a trailer having gross weight of 2-3 metric tons on level road or for cultivative work in low gears." medium load--"pulling a trailer with gross weight of 4-5 metric tons on level road or harrowing/cultivation in low gears."
2013 Ford F-450 Reading Service Truck (A61573)
2013 Ford F-450...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
JOHN DEERE 2040 TRACTOR (A63291)
JOHN DEERE 2040...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
3PT BOG HARROW (A63291)
3PT BOG HARROW...
1994 SHOP MADE ENCLOSED TOOL TRAILER (A63569)
1994 SHOP MADE...
