New Tractor Break-in procedure
/ New Tractor Break-in procedure #61
With synthetic, you can go 400 hours. With a dino oil, you better change every 100 hours. Others: in between.
A tractor's engine's life is not particularly severe service. It just makes more noise because there is no sound deadening between you and the engine like on a car, SUV or truck.
/ New Tractor Break-in procedure #62
I guess that will depend upon what your tractor is asked to do, mine get worked.
/ New Tractor Break-in procedure #63
The oil change interval really depends on when the oil no longer falls into the various specifications it needs to meet due to degradation, additive depletion, excessive combustion byproducts in the oil, etc. This depends on the spec oil used, how much oil is in the engine, the engine's power density, the engine's intended usage cycle, the fuel used, and so forth. The owner's manual has the specifics, but in general under ideal conditions the maximum oil change interval is in that 500 hour +/- 100 hour range for most new equipment. Unless a specific oil is called for to achieve that oil change interval, it doesn't matter if it is synthetic or conventional as both types of oils have to meet the same API specs and would yield the same minimum performance that is assumed when the interval recommendation was made.
A specific individual tractor engine may not live a hard life but in general a tractor engine is considered to be severe service and they are normally rated to be run for their entire service life at full rated power. Note that these same tractor engines at these same ratings are used as industrial engines for prolonged 100% loads such as pumps and generators. An on-road heavy duty engine such as a diesel engine in a heavy truck is designed to be run at a lower duty cycle and a light duty engine much less than that. Making more power leads to a shorter service life, so one way to prolong service life in a usage where the engine is being run at or near full power is to limit the power output. This is why tractor diesel engines make notably less HP/cid than heavy truck engines and far, far less HP/cid than 3/4 and 1 ton pickup engines do. For example, the roughly 400 cid diesels in current 3/4 and 1 ton pickups are being rated in the low to mid-400 HP range. In a medium duty truck, these same engines are rated for in the low to mid 300 HP range as the engine is asked to do more work and for a longer period of time. In a tractor, that size of engine (and in the case of some of Cummins' engines, the exact same engine) will be rated no higher than 300 HP.
/ New Tractor Break-in procedure #64
The B owners manual says 200 hours. That's what I'll follow. Probably good for 400 hours with synthetic.
/ New Tractor Break-in procedure #65
“In winter, operate the tractor after fully warming up the engine “
operating the tractor and putting load on the engine is the only way to fully warm up the engine around here.
2014 Dodge Grand Caravan Van (A61574)
2014 Dodge Grand...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
2011 Chevrolet Silverado 1500 Work Truck (A62613)
2011 Chevrolet...
(4) 3" X 12" HYD CYLINDERS (A64280)
(4) 3" X 12" HYD...
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
(2) FORESTRY TIRES ONLY (A64276)
(2) FORESTRY TIRES...
