New to us Ford 3000 questions?
   / New to us Ford 3000 questions? #1
8NLUGNUT
Central Texas
Several Fords, four Japanese tractors
We picked up a Ford 3000 Tuesday and really like it so far. It's gas with a transmission PTO.
Since we never owned a thousand series ford we've already come up with a few questions.
The I&T book can't get here soon enough.
The first thing that jumped out at us is the original instrument panel has been replaced with some gauges.
There is no ProofMeter(?), hour meter, or temp.
Here are a few questions so far.
1. What was connected to the back of the generator?
2. What was connected to the three plugs(?) on the back left side of the engine?
3. There is an electric fuel pump mounted. Was that original? The Holly carb leaks. Is that because there's no pressure relief valve on the pump?
Just shooting in the dark here.
Help Soundguy.
   / New to us Ford 3000 questions? #2
i see twin sticks.. so it must be a 6spd or 8spd tranny. most 3000's were 8spd.. 6spd usually fell to the 2000's
Have you decoded the model id to verify it is a trans pto. sheet metal looks post 68
model id for a 8spd 3000 with gas and live pto would be:
C1023C
ic it was non live for some reason..
C1022C
this number is on the trans bellhousing aft of the starter.
originally had a fuel pump on the front of the engine. leak at the holley carb? Take the tractor sn and date and holley info in and get the correct kit.. and I think i'd fix the oem fuel pump.
don't worry about the last pic.. them plugs are suposed to be there.
conenctor on the back of the genny was the tach drive cable nipple.
soundguy
The C1023Csound right. My brother has all that stuff. If he doesn't post it up I'm going out today to the ranch an get it.
It's 8 speed. Also have to get the rpm's down to push the pto lever in gear. Still grinds. Only way to not grind is stop stop the engine.
Is the original a mechanical fuel pump?
The Holly leaks. I figured over time the fuel pump had forced fuel into the carb after each shut down to the point of causing a leak. I don't know if that's even possible.
Thanks for the quick reply. This tractor will really help this summer with all the rain we had. We put the new shredder yesterday on it and it really hums.
   / New to us Ford 3000 questions? #4
it should have a dual stage cluch and live pto.. if you stomp the clutch and the pto grinds, then the pto stage ain't releasing
check pedal freeplay adjustment first. that's about all you can do.
at some point he clutch wears enough that you just have to repalce it.
mechanical pump
soundguy
We put a good 4 hours on the tractor today shredding. Ran fine except the rear axle seals are leaking and it makes for scary stops.
I couldn't feel a second break in the clutch for the PTO. We need to try adjusting the clutch. I'd rather not split the tractor.
Here are all the numbers I could read.
Bell Housing
1023C
QJ029 or QJC029
No third row visible.
Tranny
C7NN7006 AK
Block
C7NN6015 AH
Hope the numbers can help. Thank for helping Soundguy.
I couldn't get the 8N started today. She must be offended by the newcomer.
   / New to us Ford 3000 questions? #6
the 1023c is part of the model id.. 8spd 3000 with gas and live pto
the other numbers should be a serial number and then a date code. date code will be a number for year, letter for month, then a number 1-2 digits, then an A-B-C for shift. , digits in middle are day of month... serial number will start with a C for us models.. and a B for basildon england models, and A for antwerp belgium models..
soundguy
I'll have to remove paint and try something else to get those numbers and letters back.
They look like they were sanded down on a repaint and are now very faint at best.
Here's a link to the ford codes for those who are following along.
FORD CODES and SERIAL NUMBERS
I forgot. We ran it dry and put 10 gallons in it. We couldn't get it started for a while then I realized the fuel pump was not running. I tapped it with a screwdriver and it started right up.
Soundguy. Like you said, fix the mechanical pump.
   / New to us Ford 3000 questions? #9
it's a PITA where it is.. but it DOES work... :) same witht he carb. when it works.. it works good.. very efficient on fuel..
   / New to us Ford 3000 questions? #10
try some crayon anf a rag on the numbers.. or a mirror sometimes help with bright light..
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
1274 (A50490)
1274 (A50490)
1996 NEW HOLLAND 3930 WITH LOADER (A51243)
1996 NEW HOLLAND...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2008 CATERPILLAR 320D L (A50854)
2008 CATERPILLAR...
