Thomas
Epic Contributor
- Joined
- Apr 6, 2000
- Messages
- 31,628
- Location
- Lebanon,NH.
- Tractor
- Kubota B2650HSD w/Frontloader & CC LTX1046 & Craftman T2200 lawn mower.
Tractor stuck and muddy join the club with the rest of us.
It looks like your gravel drive is a hill, correct?View attachment 584174
Tried my hand at my drive way. Not 100% but happy for a first go at it.
Ywa, i have a shorter, but steeper hill on my gravel drive. Grading downhill? Works great. But, of course, over time and rain, a lot of my gravel ends up at the bottom of the hill. So, i try and pull it back up. I've never done a great job. My little beast does have the turf tires, so that doesn't help. I've added weight to the front at times, and that makes a huge difference. Just really looking forward to getting a new machine, something a little bigger, heavier, with grippier tires. Also, will love the fel with a grapple. I'm surrounded by woods on 3 sides, and over the years, there's been a lot of trees I'll be able to use the grapple to help clean upYes, it does slope down. It's not steep by any means. With that being said, while I was running the box on it I did stop myself a couple of times. I place the blame on me not having the box set correctly. The teeth were not required and set up completely out of the way. I experimented with the top link and that's where I ran into loss of traction. I say that it was my fault because after playing with the adjustment I was able to draw up an overflowing box and I could pull it up, down, and sideways. I will try and take pics of the area I am starting to clear off. I was thoroughly surprised how capable this tractor was. I did run I to a few instances where I had to use the hoe to break loose some dirt and buried trees and saw them to more acceptable lengths. I honestly probably should have went with the RK37. My thought process is this, the 37 would be considerably less maneuverable and more prone to tip. I basically own 10 acres of hill side. The only flat spot is the first 30yds of my driveway. I went with the 24 for its smaller stature. I know it's a bit small for what I'm trying to set up but will be the perfect size to hold what I got when it's set up. I figure, work slow, work smart and it should do pretty much everything the 37 will do just with smaller "bites". I feel obligated to make sure that you understand my opinion is Im honestly impressed with the lil guy but I truly have nothing to base it against so take it with a grain of salt.
You're right, i think the rk24 is actually a larger frame, heavier built tractor than the new bx80, either the 23 or the 26. That's the main reason i started looking at it.Yes, I am still happy with the RK. I too was bouncing back and forth from the Kubota and RK. Take this with a grain of salt because the experience I have with the BX23S is all on the lot. I personally think the RK 24 is noticeably more tractor than the BX series. To me its the equivalent to the B2301 series. I would think you would appreciate the difference between the BX1800 and the RK24 more that between the BX and BX. I do not know enough about MF to give any input worth anything on them. As far as RK goes, I truly am happy with the whole experience. Even considering the grapple took like almost 2 months more than estimated. Super nice people and like for like set up coming in at almost 10k less than Kubota. Hard to beat. If you are a large scale farmer I could see the benefit of sticking with a more established manufacturer at this time but Harry the homeowner really needs to check out what RK is offering.
****, that's what i get for working too many doubles in a row. Scratch what i wrote this morning. I just went over what i wrote and went over my numbers on the bx quote and i was wrong. Not sure what i was looking at. The bx is more expensive, by about $800.You're right, i think the rk24 is actually a larger frame, heavier built tractor than the new bx80, either the 23 or the 26. That's the main reason i started looking at it.
Surprisingly, when pricing them out, the rk is more expensive than the bx2380. My dealer has recently quoted me $13000 for the 2380, fel, and 60" mowing deck. The exact same set up through rk is $15200.
I've got an email back out to the kubota dealer about some questions, namely if the loader deck pin-on or qa. Also wanting a 54" deck due to layout of my property.
Plus, wanting dealer to install a 3rd function to use with a grapple at some point.
At 35, 3 does start to wear on me. After 10 or 11, your kinda numb.****, that's what i get for working too many doubles in a row. Scratch what i wrote this morning. I just went over what i wrote and went over my numbers on the bx quote and i was wrong. Not sure what i was looking at. The bx is more expensive, by about $800.
****, at 55, i guess working my 3rd double in a row is kicking my ***.
