New to tractors.
   / New to tractors. #1
bluezebra58
Washougal, WA
3032E John Deere
I inherited a Jd 3032E and I don't know much about tractors. I cut the pto shaft on my new cutter too short so I am trying to measure the spline to get a new one. I measure just over a inch across. Is that a 1 3/8 spline is my question? Thanks for any help out there.
   / New to tractors. #2
I assume you are referring to the shaft coming out of the back of the tractor? If so, then yes it is a 1 3/8" 6 spline shaft. Not sure what cutter you have, so not sure what size shaft is on that. Many times, it is 1 3/8" 6 spline also.
   / New to tractors.
Yes I was asking about the back.The cutter is a frontier 48" so I assume it's a 1 3/8 also right?
   / New to tractors. #4
A picture would help.
If it's a brush hog (one spindle with swing-away blades) then it will most likely be a smooth bore on the gear box with a shear pin designed to break if you hit something hard like a stump. Protects your tractor PTO from damage. If the cutter came with a slip clutch then it could be splined.
If you're talking a finish mower (3 blade spindles with a belt connecting them) then it could be either type because the belt can slip if you hit something.
At 48" on that size tractor I would guess that it is a brush hog and it is a smooth bore on the mower end. Just a guess though!
   / New to tractors. #5
If it's a Frontier RC2048 Rotary Cutter, the gear box end yoke is 1 3/8" ID
   / New to tractors. #9
I would suggest you watch some videos on youtube that show how to shorten the PTO shaft. Particularly the video by EverythingAttachments.com with Ted Corriher. May be too late this time, but if you ever need it again, you'll know how to do it properly. Good luck.
ATTENTION! PLEASE READ (A53317)
ATTENTION! PLEASE...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
2017 Ford F550 Chassis (A55973)
2017 Ford F550...
Case TV380 (A53317)
Case TV380 (A53317)
2018 John Deere Gator (A56469)
2018 John Deere...
2021 John Deere 3025E (A53317)
2021 John Deere...
