New to tractors
   / New to tractors #1
movnviolation
Hesperia, Ca
53 Ford Jubilee
Just found this site and thought I would lurk. Just bought a 53 ford Jubilee from my neighbor. He has owned it for about seven years, and it has been sitting for about six yrs. I picked it up for a song with a blade and brush hog.
Drug it home and tore into it. Pulled the carb, gas tank and radiator. sent off for parts. New carb kit, points, cond, cap, wires, plugs, gas bowl assembly, rad. hoses, etc. There was old gas in the tank. dumped it out and put a couple gallons of acetone in and shook it for a while. When I poured it out, it was fairly clean. Flushed radiator and it was pretty clean also. When I filled it up, I used distilled water and coolant.
When I got my parts, I went to work. Put new gauges in it also. I had put trans fluid in the cylinders and let it set. When all was said and done, it started right up and runs good. I will play with the timing.
I will have to get a pan gasket to stop the only leak on the tractor. Hydraulics work good.:united-states:
   / New to tractors #2
Sounds like you got a deal. I have a soft spot for Jubilees, I have spent many many enjoyable and many not so enjoyable days on one. take your time and learn what you can here and be careful any tractor is a dangerous machine. One thing to watch is Jubilees were known to have week breaks so be aware of that. Ed
   / New to tractors #3
Welcome to the forum. It sounds like you have had good results! :thumbsup:
   / New to tractors #5
Welcome. Sounds like a great deal. The old Fords seem to be on the path of running for ever. Lots of old 8n and Jubilee's still working.
2019 Ford F-150 Crew Cab 4x4 Pickup Truck (A53422)
2019 Ford F-150...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A55302)
John Deere 6105E...
2000 GULF STREAM CONQUEST (A54756)
2000 GULF STREAM...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 84"...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55218)
Neckover GL24-2-7K...
