Buying Advice new to tractors
   / new to tractors #1
newbegingsfarm
none
I am looking to buy a tractor for a small farm .The question is what type of tractor and what horse power tractor do i need to run a 7 ft bush hogg and a 2 possibly 3 bottom plow and a 2 row corn harvester and a nice set of disks ? what would be the ideal tractor for me it will be used on a 10 acre hobby farm . thankyou
   / new to tractors #2
I have 10 acres of flat pasture, 6 acres in hay. My tractor is a 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, gear tranny, power steering) with the ML250 FEL (6-ft wide bucket, 2950 lb lift to 10.5 ft height). It'll handle the implements you mentioned and then some.
   / new to tractors #3
I don't know about the corn harvester (chopping or picking?), but the rest of your tasks could be handled by a vintage 50-60 hp farm tractor, or a new CUT tractor with 4wd and around 35-50 hp.
Will
   / new to tractors #4
I have to agree with Will_c, about the sizes. I have around 10 acres that I keep maintained, (not perfectly) with my 5 foot bushhog and 2816 Mahindra. My biggest worry was that I would get a tractor too big to fit in normal places, such as between trees or in my barn. Take a look at the CUTS (compact utility tractors) the options are endless, especially in the 40hp range.
   / new to tractors #5
7' rough mowers are that weird inbetween point from 1-2 gearboxes.
6' is 1 gearbox.. and not too heavy.. 7' is usually i gearbox and 1 or 2 tailwheels.. and quite heavy. 8' gets you 2 gear boxes and 2 tailwheels.
In many cases 8' hogs handle better than 7' hogs.. they aren't as long either.. ie.. only a little longer that 4.5' rear of the tractor..
for 10ac.. I'd think something in the 45-50hp range for a 6' mower and easy on a 2 bottom.. perhaps a 3rd depending on soil. Not sure what the corn chopper needs. ford 8xx or 4000 3/4 cyl series would be ideal.. and cheap too.
if you are dead set on a 7' mower.. I'd go ford 4000 3 cyl minimum.. for a lil more.. a 5000 and 10' mower can be had.. etc.
soundguy
TCM FD30T6T Forklift (A55973)
TCM FD30T6T...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
John Deere CP24E (A53317)
John Deere CP24E...
2015 Chevrolet Silverado 2500 4x4 Crew Cab Pickup Truck (A56858)
2015 Chevrolet...
UNUSED FUTURE FT-72 72" HYD MULCHER (A57193)
UNUSED FUTURE...
2018 Ford F150 (A55973)
2018 Ford F150...
