Buying Advice New to Tractors- Need Advice on choosing
   / New to Tractors- Need Advice on choosing #11
I first zeroed in on the the little BX25 in the Kubota catalog.
It looks rather small but probably would get the job done except the bucket is 5-6 cubic feet
which seems tiny.
My neighbor got a couple of dump truck loads of manure for his garden last week .
The other day i saw him trying to spread it with a shovel.
This morning he came over and ask me if I'd spread it on his garden for him with my BX23 so I did .
Aparently neither the tractor or the bucket looked small or tiny to him after the bout with the shovel the other day.
Re: My New BX25 ARRIVED TODAY!
As I said, you will love that BX..Moved 24 ton of limestone and 35 heaping one ton dump truck load of dirt over the last two days...Love this thing!!!
__________________
BX23TLB & RTV1100 with 72" Power Angle Plow
   / New to Tractors- Need Advice on choosing #12
I feel your pain in the confusion trying to sort out between the various companies and even within their product line having been there. I posted the information below as an overview of the Kubota line to a similar question. Perhaps it will help although obviously a generalization.
I will talk in Kubota terms, because I know them better, but there are obviously other good brands.
The BX size Kubota is a SCUT or Sub Compact Utility Tractor. Great mower which can do a lot more than a garden tractor. HP ranges from about 18 - 26 HP. It can have a loader added plus use equipment off the 3pt hitch in the back such a rotary mower commonly called a brush hog for mowing field type grass, a rear finish mower (RFM) or have a mid mount mower (MMM or belly mower). It is small enough to into relatively confined areas such as stall areas maybe. It is limited by weight of the tractor, power of the hydaulics, and perhaps most by clearance under the tractor. But the clearance is only isssue obviously by what you would need to go over.
The B size Kubota is a CUT or Compact. Still a good mower and has the ability to still use a MMM. Also has the 3 pt hitch and power take off on the rear like the BX of course so you can use the mowers on the back as well but can use a little larger. On BX you might want to stick to a 4' rough cut mower but on a B could move up to a 5'. HP ranges from 23 to 32 HP. The tractor is a little heavier, has stronger hydraulics so can therefore handle a little bigger chores. It also has higher ground clearance so less issue with traversing in most areas.
The L size Kubota is a UT. The HP starts about 28 and goes to about 44, although I am not as familiar with it, but that's ball park. Now unless you go to the Grand L, I don't think MMM can be used, so you only have the rear mower options. As with the move from the BX to B, you are moving up in weight of the tractor and power of the hydraulics.
With that, the best thing is to go to a local dealer and sit on a few. Once you get a general feel, any dealer should let you test drive them. With minimal explaination, you should be able to at least be able to drive them around the lot. My wife had never been on a tractor when we test drove them, but was comfortable operating a BX and 2 B's as part of the decision. Even if you decide to buy used, this process will help you target what you are looking for.
Like with most thing, there are times when it will be too small and sometimes too big. Try to determine what you will be spending most of your time doing try to decide what will work best for those applications and improvise, rent or contract the other work. We bought the B size. It works for us well to do what we do most of the stuff we do and I didn't want to go to an L since I trailer it to our other property, but sometimes I wish for the L, but that is when I am clearing areas of brush. If I was in more of a hurry, I would hire someone with a bulldozer to clear it quick.
   / New to Tractors- Need Advice on choosing #13
I suggest you look at the "Why you need two tractors" thread ..... LoL!
I only wish our B2410 had a FEL, if it did, it would virtually be garanteed a place on our "farm" until it dies or is destroyed. It does EVERYTHING you need a CUT to do and most of what you need a mower and UT to do.
   / New to Tractors- Need Advice on choosing #14
I added a loader to my B8200 a couple years after I got it. I went with a Bushhog. It was a great addition. For me, it really made it a "tractor".
It was, about $3k installed though; certianly not inexpensive.
   / New to Tractors- Need Advice on choosing #15
I would agree. My B8200 loader was pretty small. It was a LOT better than a shovel and wheel barrow. It held, a little over a wheel barrow load in the 4' bucket.
A smaller tractor will do most tasks. It just takes longer.
If I had 2-5 acres, but occasionally did something on a larger scale, a BX or equivalent would be fine. For 3-8 acres the "B" series, or NH TC29 for example, is a nice fit. Getting up to 10 acres, a "B" is ok, but a "L" or other brand equivalent is a lot nicer.
Go to a "B" or an "L", and your loader is bigger, the mower is bigger. So your BX can do great at moving a ton of gravel. A "B" could do it almost twice as fast because of the larger loader.
In my case, I got a larger tractor than planned because of the deal I got. My NH TC40DA has a 1/2 yard bucket. Wanna move some gravel and rock :D.
Having spent the last 12 years taking care of a 5 acre parcel, and another almost 8 acres, I would definitely want something bigger than the BX. And, bigger(at least HP wise than my old B8200. Something at least in a large "B" series, or mid "L" series. My BIL takes care of his 10 acres with an older L2850, with 34hp. That works out really nice.
   / New to Tractors- Need Advice on choosing #16
The L size Kubota is a UT. The HP starts about 28 and goes to about 44, although I am not as familiar with it, but that's ball park. Now unless you go to the Grand L, I don't think MMM can be used, so you only have the rear mower options. As with the move from the BX to B, you are moving up in weight of the tractor and power of the hydraulics.With that, the best thing is to go to a local dealer and sit on a few. Once you get a general feel, any dealer should let you test drive them. With minimal explaination, you should be able to at least be able to drive them around the lot. My wife had never been on a tractor when we test drove them, but was comfortable operating a BX and 2 B's as part of the decision. Even if you decide to buy used, this process will help you target what you are looking for.
Like with most things, there are times when it will be too small and sometimes too big. Try to determine what you will be spending most of your time doing try to decide what will work best for those applications and improvise, rent or contract the other work. We bought the B size. It works for us well to do what we do most of the stuff we do and I didn't want to go to an L since I trailer it to our other property, but sometimes I wish for the L, but that is when I am clearing areas of brush. If I was in more of a hurry, I would hire someone with a bulldozer to clear it quick.
Good info in this post.
1*I only wish our B2410 had a FEL, if it did, it would virtually be garanteed a place on our "farm" until it dies or is destroyed. It does EVERYTHING you need a CUT to do and most of what you need a mower and UT to do.
1*I almost bought a used B 2410 with a loader back in 2004.
Got a price on a used 2002 but decided to see what a new one cost at my dealer.
That's when i saw the BX23.
It was love at first sight so I bought one from a dealer in WV.
43024 (A59228)
43024 (A59228)
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2021 Ford Mustang Mach-E AWD SUV (A56859)
2021 Ford Mustang...
1449 (A57192)
1449 (A57192)
New/Unused 10ft X 20ft Single Garage Metal Shed (A57454)
New/Unused 10ft X...
Midwestern Industries MEV Screen Model MEV 5X10-2 (A56436)
Midwestern...
