Need Advice on Which Model
   / Need Advice on Which Model #11
If you want to simply make a trail across the swampy area (heed the earlier warning about "registered wetland") - simply get some fill and put it down as you go. If you have fill that you can take from another location you can save some money. You'll want a couple of pipes across the path to let water flow. Only needs to be as wide as the tractor. When working in the woods, small is good if you want to leave little damage.
I'm partial to the Kubota B series - the small frame is easy to work on/with.
Good luck!
Mike
9ft Flatbed (A57453)
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
125 Gallon Water Tank (A57454)
125 Gallon Water...
John Deere 250 D Off-Road Dump Truck (A57453)
John Deere 250 D...
