New to TIG, trying to weld aluminum with no success
   / New to TIG, trying to weld aluminum with no success
This is an old thread, but I sure hope the OP got someone else to build the ladder. :ROFLMAO:
I did, sort of. I gave up on aluminum since an AC TIG is outside my budget (or needs) right now. Instead I welded up steel brackets and bolted them with stainless steel screws. :)
   / New to TIG, trying to weld aluminum with no success #32
I weld aluminum all the time with AC. Aluminum forms an oxide layer almost immediately. Oxide melts at about twice the temperature clean aluminum does & you can't make filler stick to it.
I have tried welding DC. You have to run Electrode Negative. It only works in thick stuff. Form a puddle you can't really see because of the "skin" then plunge the filler through the skin into the puddle. It will not be a pretty weld.
   / New to TIG, trying to weld aluminum with no success #33
Looks like the problem was solved. I would have used stainless instead of the Aluminum with a DC only TIG.
   / New to TIG, trying to weld aluminum with no success #34
Old thread but, you started out wrong. You never prep aluminum with a steel wire brush, always with a stainless steel wire brush and you ALWAYS wipe the aluminum with either acetone or laquer thinner prior to welding.
KSI Conveyor (A52748)
198367 (A51243)
198367 (A51243)
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
2001 John Deere M665 (A50120)
2001 John Deere...
