Dirt Moving New to the forum
   / New to the forum #1
Dirt Doctor
Hollister, California
Volvo l50b, Kubota r400
Hi all,
I have a 90 Kubota R 400 loader / backhoe, with all the goodies, 4 in 1 bucket, 3/4 yard, 1 yard light materials bucket, fork attachments, auger, and a few other misc. things.
I would like to talk with any other R400 owners and see if they have had issues with the hydraulic oil, I hear what sounds like cavitation but I'm not sure. The oil is coffee/cream colored. I have loaned it out to friends and I am not sure what has happened. It works fine once it has a chance to warm up, the cavitation noise seems to disappear.
The Transmission oil (engine oil) seems to remain clear, even though when it starts up, there is a slight 30-40 second lag before the unit takes off. I had EVERYTHING serviced at 2600 hours about 300 hours back. Engine oil and filters were changed 100 hrs back.
This loader gets very little use, just digging a trench or moving manure for a few hours a month. I have no shop or overhang to park it under so it does get more weather than I would like.
ANY SUGGESTIONS?
Thanks
JAck dirtdoctorjak@aol.com
   / New to the forum #2
You either have water in the hydraulic oil or a loose suction hose if it is clamped with a hose clamp.
If it remains creme colored you should change the oil and check the suction line for a pin hole leak or a loose hose clamp.
The pumps may need to be changed if it continues as you rmachine is 20 years old.
   / New to the forum #3
Welcome to the forum! I would think there are others who own similar equipment and hopefully will post. Color does sound like water or moisture in oil.
   / New to the forum #5
Welcome to TBN. Should get your answer here.
   / New to the forum #7
Welcome to TBN:thumbsup:
   / New to the forum
Thanks for the hearty hello,
I will be pulling the filters on the hydraulic tank tomorrow and get the scope out to see the insides. I will double check the suction hoses and check for leaks too.
At 2000 hours I took the tractor in to the Local C & N tractor guys, told them to go through all filters, screens, replace all oils, filters, replace a broken bolt that holds the Backhoe Frame to the tractor etc.... 2 Weeks later and $2600 dollars in their pockets, I got my loader back, It sat for almost a year. Then I loaned it to a friend and he changed the oil and found an original filter dated 4/99 on it. That made me wonder what work the dealership did, so I checked to see if they had replaced the broken bolt... nada still there. That dealership just did not have a clue.
jack
2020 Deere 325G (A50123)
2020 Deere 325G...
2017 Can-Am Side by Side (A51694)
2017 Can-Am Side...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A53472)
2000 John Deere...
1837 (A51248)
1837 (A51248)
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
