New to the forum, problems with cub 3165
   / New to the forum, problems with cub 3165 #1
tuxedoman
tyler Hill,pa
Cub Cadet 3165
HI I am new to the forum and I am having a problem. After replacing the vacuum actuator it worked great but then the engine started to miss when mowing in higher, wet grass. Any thoughts? Thanks.
   / New to the forum, problems with cub 3165 #2
The trouble may be unrelated but my motto is to always check the obvious first. Double check all the vacuum hoses anywhere near the actuator you replaced. Ay vacuum leaks will cause a lean condition ad could affect the engine under heavy load. It can cause valve burning if it continues. Also you might check the new actuator to make sure it doesn't leak. If you have a hand vacuum pump, which I've found handy for many things including auto brake bleeding, you can attach it to the actuator and see if it holds the vacuum. Without the pump you can try sucking on an attached hose to see if it's sucking in air. Other than that it could be the usual - plugs, bad gas, fuel problems etc.
Bob B.
Thanks bob for your speedy reply. I do not have the vacuum device you describe, I will try with my mouth. You’ll actually describe the problem better than I do. Probably be a day or so until I get to it and hopefully you were right, that it is something obvious.
Thanks Jeff
2022 Carry-On 5'x8' Trailer (A53316)
2022 Carry-On...
UNUSED FUTURE SZYMJ HYD STUMP GRINDER (A57193)
UNUSED FUTURE...
Water Trough (A56469)
2024 Schulte 5026 Batwing Rotary Cutter (A55315)
2024 Schulte 5026...
2013 Ford Edge Limited AWD SUV (A55853)
2013 Ford Edge...
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
