New to the forum, problems with cub 3165
   / New to the forum, problems with cub 3165 #1
tuxedoman
tyler Hill,pa
Cub Cadet 3165
HI I am new to the forum and I am having a problem. After replacing the vacuum actuator it worked great but then the engine started to miss when mowing in higher, wet grass. Any thoughts? Thanks.
   / New to the forum, problems with cub 3165 #2
The trouble may be unrelated but my motto is to always check the obvious first. Double check all the vacuum hoses anywhere near the actuator you replaced. Ay vacuum leaks will cause a lean condition ad could affect the engine under heavy load. It can cause valve burning if it continues. Also you might check the new actuator to make sure it doesn't leak. If you have a hand vacuum pump, which I've found handy for many things including auto brake bleeding, you can attach it to the actuator and see if it holds the vacuum. Without the pump you can try sucking on an attached hose to see if it's sucking in air. Other than that it could be the usual - plugs, bad gas, fuel problems etc.
Bob B.
Thanks bob for your speedy reply. I do not have the vacuum device you describe, I will try with my mouth. You’ll actually describe the problem better than I do. Probably be a day or so until I get to it and hopefully you were right, that it is something obvious.
Thanks Jeff
Auger (A53316)
Auger (A53316)
4-295/75R22.5 Tires And Rims (A50775)
4-295/75R22.5...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
2006 Ford F-250 4x4 Pickup Truck (A55788)
2006 Ford F-250...
2006 Isuzu NPR 16ft Box Truck (A55788)
2006 Isuzu NPR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
