New to plowing.
   / New to plowing. #1
Ghoakie
John Deere 5400
Hello everyone. I am starting a small farm in Pennsylvania and new to farming. We are doing organic and have a problem with ragweed so I need to plow to put down a cover crop soon. Many people have suggested that I get a moldboard plow but I'm not sure what size, type and how many bottoms would be best in my situation. I will only be plowing food plots on 6 acres at first.
I have a 60hp John Deere 5400. Any advice would be helpful.
So far I have found an old full mount JD 3 bottom trip plow at a used dealer that was repainted.
Thanks
   / New to plowing. #2
A three bottom should be perfect for your tractor. I pull a old Ford 101 three bottom with my 70 horse Kubota, and it has no trouble. Works absolutely great. Trip bottoms are a must. Mine has shear pins which work great. I may go thru 2 or 3 pins (I use plain 3/16 grade 8 bolts) over the course of a plowing session, but my soil is rocky. Changing a pin is a 1 minute fix. Spring type trip protection may be ok also, but more complex. But I have no experience with that. Just check out the wear parts (shares, shins, moldboards) as some old plows are shot. Replacing all three can cost about $150 per bottom. Some say the old Ford 101 is hard to beat, better than a Deere, but thats only opinion. Posting a picture of the plow and its bottoms would be helpful for us to evaluate. Expect to pay $400 up to $700 for a really nice one. Oh, make sure the trip works, and it is not locked up. This is important as a plow without a good functioning trip can easily be damaged, so I learned the hard way! Loading your rear tires also helps in pulling.
Don't forget after plowing, you still must further prepare the soil with a disc or rotary tiller, and then level with some sort of drag. Hope this helps.
   / New to plowing. #3
Something like a 3-14 bottom Ford 101 trip beam plow would work or maybe to cover the trash better a 5 disc plow that takes 30 inches at a pass. Ken Sweet
   / New to plowing. #4
Here are the pictures for the above post. Ken Sweet
FAKE (A52472)
FAKE (A52472)
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2013 FORD F650 ROUSTABOUT (A52472)
2013 FORD F650...
