New to me TC29D cranks & won’t start
   / New to me TC29D cranks & won’t start #111
Too much blow by and very little resistance to cranking per compression stroke. Likely they started it with either until it wouldn’t start anymore. Time for disassembly.
Injector and pump “pop” test in progress tonight
Also anyone know for sure I can drop oil pan ? Looks to be a crossmember and possible front driveshaft in the way.. last picture attached …
Pop test vid looks like 1 good 1 fair and 1 bad injector but pump looks to be working to my eye. What do the pros think?
What is next on the to do list everyone?? Besides spray some air freshener and get beard balm on, all I smell is diesel #2 lol
   / New to me TC29D cranks & won’t start #115
Swap the one that’s NOT PUMPING to a different line..
THATS to rule out a bad cyl in the pump..
(y) Are these type injectors rebuildable or cheaper just to get new?
   / New to me TC29D cranks & won’t start #117
Something else I was thinking about. I’m used to doing compression tests by removing the injectors, not the glow plugs. If you do a compression test using the glow plug holes, can the injectors leak enough to throw off your test?
   / New to me TC29D cranks & won’t start #118
That’s almost funny. If the injectors leaked back how would they handle the explosion?
The surface area of the nozzle is so small it can’t push back. The blow by tells the story. So much guessing on here the guy is just chasing his tail until the main thing is corrected.
   / New to me TC29D cranks & won’t start #119
Are you always arrogant and pissy ?
   / New to me TC29D cranks & won’t start #120
Facts are facts.
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2019 KENWORTH T680 SLEEPER (A52577)
2019 KENWORTH T680...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2017 Ford Fusion Sedan (A50324)
2017 Ford Fusion...
RURAL KING RK37 TRACTOR (A51243)
RURAL KING RK37...
