Forks New (to me) pallet forks
   / New (to me) pallet forks
I don't think I can add to the sides. It would be too wide. The SSQD is out of the question as I'm too tight to spring for it. I did buy the deere "hooks" for the top of the JDQD mounts. The bottom JDQD pins are the same size as cat 2 pins. So I'm going to get a couple of those and cut them down.
Well, I finally made it up to the farm. It looks like this is going to be a little harder than I thought. First I ran out of oxegen and acc gas. :mad: Then the lower corrention is going to require some enginnering to make work. The rake angle is wrong and the "pins" are "outside" of the attachment .
   / New (to me) pallet forks #13
Can you add a small plate or square tubing to the top and attach the JD hook? Can a piece of heary angle iron be welded to the side and weld a short bar or bolt to the angle iron to make the pin for the bottom of the FEL?
   / New (to me) pallet forks #14
$350 was a bargain.
The JD top hook will fit on the plate at the top just fine as is. The bottom pins got me stumped as to how to do a nice clean job without too much work.
Well, I finally got some time to devote to this project. I ended up cutting most all of the skid steer mounts off and adding 2 7" standard c channel on both sides. I used the JD hooks and pins.
   / New (to me) pallet forks #18
Good job, looks like you are alll set.
Steve
Spirit scooter (A55787)
Spirit scooter...
9202 (A50322)
9202 (A50322)
RAKE ATTACHMENT FOR MINI-EX (A55745)
RAKE ATTACHMENT...
Deere 35P (A53317)
Deere 35P (A53317)
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
(2) GAS HEATERS (A54757)
(2) GAS HEATERS...
