New(to me) Old Lincon SA-200
   / New(to me) Old Lincon SA-200 #1
sailfast
Central Ohio
JD 5055, Mahindra 315, JD 2040
So I dug the SA 200 out of the back of the pole barn. It seems that it was last used about 8 years ago on a building an indoor arena project.
I have never welded before...
Is this a good machine for me to learn to weld with?
What should I do to this long neglected machine to get it up and running again?
   / New(to me) Old Lincon SA-200 #2
I have 5 SA-200's. Can you post a picture of your new machine? Or post the serial number off the face plate and I can tell you the year.
   / New(to me) Old Lincon SA-200 #3
there is one in the local classifieds, for $100. The ad says complete SA-200 for parts, mostly in pieces. To me that means "I found a really big problem, that I cant fix/will cost way too much to fix", that and it is a 3 hour drive away, has stopped me from buying it.
I will take a pict of it this evening and try to find a serial number. It is parked in the garage at home at the moment.
I need to get it going fairly soon or I will be forced to give up it's parking space and head it back to the barn. :)
   / New(to me) Old Lincon SA-200 #6
Before you crank it over! I'd check the generator for rat's nest, and any broken wires. Make sure all 8 main brushes are free in there holders, and the 2 exciter brushes. Then remove the spark plugs and spray some WD-40 in the cylinders. Then see if there is spark from the mag. If so, drain and replace the gas. Crank it over a few times to blow the excess WD-40 out of the cylinders, replace the spark plugs, and then see if it will fire off. That should keep you busy for an hour or so.:D
THanks for advice.
I am sure that if it sets in the garage for more than a week without visible progress the wife will banish it back to the pole barn.
I will post a serial number this evening.
   / New(to me) Old Lincon SA-200 #8
If there is no spark, simply cleaning up the points was what worked for me.
Ok. Finally got home before dark and was able to check the serial number.
939296
Thanks
   / New(to me) Old Lincon SA-200 #10
1980.
Octagon barrel, like this one.
2013 RAM 4500 (A50323)
DEWALT 3600 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3600 PSI...
2011 Jeep Wrangler (A51694)
2011 Jeep Wrangler...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
2024 KUHN SL124T LOT IDENTIFIER 60 (A53084)
2024 KUHN SL124T...
