New to me CUT TLB
   / New to me CUT TLB
I'm not sure what may have been done (if anything other than routine maintenense) to this 2638HST during the 161hrs that it was owned by 2 previous owners,so my thought is to verify that all settings are set to factory specs, hopefully to rule out tinkerings that may/may-not have been done by others.
I have used Howes Lubricator Diesel Treat Antigel and conditioner for the past 15hours of use and have not noticed an improvenent in the tick! Hense the reason I'm inquiring about factory injector settings.
   / New to me CUT TLB #12
I wouldn’t mess with injector timing unless you are pretty sure it’s been changed in the past. The ticking could be valve train related. There is usually a procedure for setting valve lash but as low of hours you have it shouldn’t be an issue yet.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2025 BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
CLAMP ON UNIVERSAL 42" FORKS (A54757)
CLAMP ON UNIVERSAL...
2017 Kubota M7-151 Premium MFWD Tractor (A56435)
2017 Kubota M7-151...
