New to me BX25, what recommended mods/improvements to do?
   / New to me BX25, what recommended mods/improvements to do? #11
   / New to me BX25, what recommended mods/improvements to do? #12
If the BX25 has the (2) in series fuel filters, then you may want to consider replacing the first one with a larger aftermarket filter. This is a common mod to some bx tractors, as well as my ZD mowers.
I put a large 2 micron fuel filter on both of my ZD’s several years ago... fuel tank > 2 mic filter > electric lift pump > oem in line filter > injector pump.
Not using Tapatalk, that makes sense. Odd though.
Great photos and detail, thank you for the link. I'll have to crawl under and look. I may have to copy your D-ring concept on the bucket.
   / New to me BX25, what recommended mods/improvements to do? #14
Check the radiator overflow bottle for a blocked cap that was the subject of a recall, simple fix if it is blocked.
Thank you for that.
Does Kubota have a website where the past recalls are listed?
Or even better, Tech Service Bulletins?
   / New to me BX25, what recommended mods/improvements to do? #17
Thanks George I'll look into that.
Changed the engine oil and filter yesterday, as there was no maintenance history from prior owner. As all the filters were white Kubota, I assume that he did the recommended 50 hr service. It has 184 hours on it now.
Lifting the tractor up via the backhoe stabilizers and FEL makes it a very easy job for an oil change. Also pulled the engine side guards off and did a detailed 360 inspection. Mine has the factory guard plate next to the HST shaft mounted fan, so no damage to report.
   / New to me BX25, what recommended mods/improvements to do? #19
A word of warning, it is easy to lift the machine up like you did to work on it, just block it up also. The problem woukd be a sudden loss of hydraulic fluid, such as a hose breaking, causing the tractor to come down on you.
I will second adding a better fuel filter. I had a lot of problems with mine plugging the cheapo factory filters. I set mine up with a Racor filter and did it without a kit. I am not the greatest fabricator so the prebuilt kit woukd have been nice.
Does the rear fuel filter get bypassed/eliminated with the Racor setup?
1997 International F-9370 Eagle Log Truck, VIN # 2HSFBASTXVC083719 (A57453)
1997 International...
2003 Ford E250 Passenger Van (A56858)
2003 Ford E250...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2014 International PayStar 5900i T/A 24ft Flatbed Truck (A55973)
2014 International...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A55973)
2015 Freightliner...
