New to me B7800
   / New to me B7800 #1
Arcane
SE MA
Kubota B7800
I've just picked up a low hours B7800, and I'll be buying a trailer next. If anyone can help me with length and weight of the B7800 with FEL and BH (probably a Woods BH80-X), so I can spec the trailer, that would be very helpful. I have to trailer the tractor to the Kubota/Woods dealer to get those implements. My truck has a GVWR of 6000, so I don't want to get a bigger trailer than I have to. Thanks, R
   / New to me B7800 #2
Congratulations on your tractor, sorry I can't help with the other stuff.
   / New to me B7800 #3
I have a B7800 and can haul it on my 12' dump trailer if I hang the bucket over the front, that is with a box blade on it. I can get the whole tractor with a rototiller and not hang the bucket off the front on a 16' trailer. A backhoe can stick out the rear between the ramps if the trailer allows. In your case I might just go with the 16' and not worry about it. If your truck only has a #6000 GVWR then you might want to think seriously about a different truck as you will be close or exceeding the max. When I got my first tractor/trailer combo I had to change trucks to be able to do what I wanted too. Just my .02;)
   / New to me B7800 #4
I haul my B7800 on a 16' trailer. Works with the brush hog or loader attached (I haven't tried both at the same time). To give some idea of the towing weights my B7820 with filled tires weighs 2,200#. The brush hog weighs 620#, the loader weighs 600#. My trailer (7,000# GVWR) weighs 1.500#. I don't have a backhoe so I can't comment on the weight of a backhoe. I like the tandem axle 16', 7,000 GVWR, electric brake one axle trailers. Seems like an ideal setup for hauling my tractor. Everyone one seems to like it also. My friends use it more than I do.
   / New to me B7800 #5
I have a 16' Dual axle trailer. I've hauled B7800, L3240 FEL, B3200 FEL F2680, BX2660 FEL MMM on it. So, I agree with whistlepig.
   / New to me B7800
Thanks for the replies and advice. The boss won稚 take to my buying a new truck to haul the new tractor, so I値l have to roll lightly for now. The local trailer shop/mfr has these:
Load Trail utility trailer, 77"x16', store under ramps, swing style jack, sealed modular wiring, pt wood deck Details Price:2250.00 CARRY CAPACITY: 5212 LBS GVWR: 7000 lbs
Equipment Hauler 82"x16', 60" stand up ramps, Dexter EZ lube axles, stake pockets & rub rail, headboard, 2k post jack, (4) 1/2" d-rings, sealed modular wiring harness, steel light boxes, LED lights, PT wood deck. Details Price:2695.00 CARRY CAPACITY: 4810 LBS GVWR: 7000 LBS
Tandem Axle Landscape trailer 82"x16', shock assisted X-treme duty ramp gate, 18" tube top rail, tie downs, Dexter axles with EZ lube hubs, 7K drop leg jack, steel light boxes, sealed modular wiring harness, adjustable channel ball or pintle ring, extended tongue, pt wood deck, prime & paint. Details SKU:WT-10-32087 Price:2795.00 Carrying Capacity: 4860 LBS Color: BLACK GVWR: 7000 LBS
Photos below are in order. What do you think?
   / New to me B7800 #7
I prefer the middle one because of the width 82" and the ramps allow something to hang out the back if need be. I do this with my 16' trailer with certain implements on. The third choice would not allow this. The first one is narrower and not built as heavy. So then #2 if it were my choice, IMHO.:)
   / New to me B7800 #8
This should be in the transportation forum.
In some states NONE of those trailers may do because some states don't allow towing a feather on a trailer with a GVWR greater than your trucks tow capacity.
   / New to me B7800 #9
I have a B 7800 with a bh 80x on a 18 ft 10,000 lbs trailer by DOT law all of tractor must be inside trailer and with BH you need 4 chains front back over front bucket and rear bucket
   / New to me B7800 #10
I imagine out east there is a little stricter than here in the midwest. I would consult all the appropriate regulations before making a firm decision. In any event you have a great little tractor, I have the same and like it more every day. By all means chain it front and rear when you haul it, an extra 2 minutes can save you from a lot of misery. Get a system down when you haul your tractor and don't deviate from it even it is just a short distance. I have dedicated chains for those tasks and follow my own advice. Electric brakes are a must have, one axle minimum, two is better. Let us know what you get.
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2013 RAM 4500 (A50323)
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
JOHN DEERE 608C (A53084)
JOHN DEERE 608C...
