sd455dan
Super Member
- Joined
- Oct 23, 2012
- Messages
- 6,293
- Location
- North Idaho
- Tractor
- Rhino 554, Ford 550 TLB (JD X500, MTD, Gilson riding mowers) Ford 3000-Sold
)So you admit, the quality even when it was new, was sub-par as, most people don't just tear an engine apart just because they want to freshen it up ..
Wrong- I never said that, and no one other than me even noticed it... but did ask why i was going to work on it- they would have left it alone.
Tearing into an engine to freshen them up is never done??
Obliviously You have never owned any hot rods or other 20 + year old engines that you might want to freshen up Whatever?.. the parts were inexpensive and i decided to replace the rings, fortunately the parts are not priced like the poor guy on a current thread with a John Deere that was quoted over 400 for each cylinder sleeve, mine cost $55 and had the Shanghai / New Holland markings on it ( They are a joint venture company). the rings were $85- that is a complete set of 4 including the oil rings for all 4
the John Deere $ 132 per cylinder!!
http://www.tractorbynet.com/forums/parts-repairs/343532-old-pistons-new-rings-not.html
Gees- that sounds similar to the to the JD engine in My 550g long track- hopefully the jd hangs in there.
The only reason I (or anyone else I know) would tear anything apart, would be because there are problems. Again,, for the few chinese tractors that are sold.. they have a lot of problems that the new major brands just don't have.
Have you read many of the posts lately? Plenty of problems...
It's also not true if he buys a used name brand ,there will be a good chance he'll be working on it...I have several friends that have bought used JD'S ,Kubota's, Massey's ,etc, and have not had to turn a wrench other than change oil, and repair flat tires...,That being said,, you can buy a used name brand, that has been beat to death..
Some cases yes some no Luck of the draw?
About your FIL's yanmar.. He most likely bought a worn out yanmar,, Also, keep in mind,, These yanmar tractors are 30+ yrs old. If the tractor was rode hard and put up wet,, it's expected to have problems..
(Your tractor or the other chinese tractors with all the issues aren't 30 + yr old tractors
no it is only 20 + years old... with all the issues?? :laughing::laughing:
for a machine that cost me the equivalent of my FILs 2310d cost him
Issues? Some of them are being able to do jobs that these little Yanmars are incapable of like -
not needing an over running clutch for my PTO when running a brush hog- so it doesn't try kill me by pushing my tractor thru a fence- (happened to FIL) before purchasing an add on over run clutch.
running an 85 inch tiller,
running an 85 inch snow blower for 10+ years-now sold
running category 2 implements with a 1000 rpm fine spline pto,
pulling a 3-5 bottom plow, and having draft control at the finger tip
pulling a 6and 1/2 ' disc harrow
lifting well over a ton with the FEL to 10 feet, which allows loading my GMC 7000 dump truck
having 3 independent hydraulic pumps- so the steering is never out of power
or the 3 point
or the FEL and power beyond for remotes.
those are some of the (issues) that are different for two tractors that were bought for the same money.
The 554 has cost less in parts replacement,and maintenance-even including the engine work done(whether needed or not)
Once again to the OP if you are in doubt or have reservations about trusting or buying a chinese tractor - DO NOT DO IT
buy the machine YOU want- be it a new or used Name Brand and enjoy it
