New Subsoiler
/ New Subsoiler #1
danbuf
Buff NY
Kubota B3030, ford 860, & Deere 445
Just picked up a Subsoiler made by A&B Eagleline.
This thing is a real brute.
I did a test dig with my B3030, and it must have gone down 18" or so without any tweaking. (4WD, Turf tires)
Its a bit pricey: $270
I also got 15" middle buster point for it.. I'll report back someday after I do some work with it..
A & B EAGLE LINE EQUIPMENT The Shield of Quality
Dan
/ New Subsoiler #2
Nice! Post some pics of the soil you are working on!
Bob
/ New Subsoiler #3
danbuf,
What will you be using it for?
/ New Subsoiler #4
Looks nice and heavy. It looks like your lower links are almost raised as high as they will go. How much higher can you raise it off the ground?
Solo
/ New Subsoiler
I plan on using it for a number of projects.. Drainage issues, waterline for garden. etc..
I hope to try ditching with the middle buster point.
As far as the height, I think this is about it.. (~4" off ground)
I just hooked and quickly tried though..Havent gotten back to it
You can reposition the shank by re-drilling the holes for brackets, to raise it, which would give more clearance.
It is built really well - 138# worth of steel..
Dan
/ New Subsoiler #6
I just bought a subsoiler too and on my Kioti the tip just barely clears the ground. Hasn't been a problem though.
How do you determine the attack angle of the tip? I made a mess out of one of my fields since the clay boulders were sprung up to the surface. That single shank needed low range and a good bit of power to pull it through. I bought the TSC model that is supposed to be a dedicated subsoiler but I can't see why a middle buster shovel won't bolt on. The angle of the tooth looks more horizontal on my yellow SS though.
I think I'll wait for the ground to moisten a bit. I bought the SS to fluff the compacted soil and improve drainage.
/ New Subsoiler #7
I have the TSC middle buster and the sub soiler blade that I purchased from TSC has a different bolt pattern but will work. If I had it to do over again, I would have purchased a heavier duty dual purpose sub soiler/middle buster. I have a John Deere 2010 that is approximately 40 hp on a good day and I would like to do some heavier work than I feel comfortable with using the TSC version.
Farwell
/ New Subsoiler #8
The combination MB SS units all seemed very light duty with weights less than half of even the TSC SS units. Availability was also an issue.
/ New Subsoiler #9
The KK subsoiler is about 6" longer a about 15lbs heaveir than the KK middlebuster.
